Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-31-2011, 06:48 PM   #1
70shortwide
drag racing with a 4l80e
i was curious who is using a 4l80e in ther race truck. i currently have a 400 turbo and it worked great with the big block but now im building a ls6 genIII motor and thought the od would be awesome. so please let me know experinces with them. thanks
70shortwide is offline   Reply With Quote
Old 05-31-2011, 07:08 PM   #2
05Gibbs
05Gibbs's Avatar
Re: drag racing with a 4l80e
they are great trannys. my friend has a pretty much stock one in his 99 with 370ci lsx with 4k stall and 456 gears with 300 shot and its been in the low 10s several times and should be in the 9s when his new engine gets broken in
05Gibbs is offline   Reply With Quote
Old 05-31-2011, 08:09 PM   #3
70shortwide
will it hold that power with just a clutch kit or do i need a different valve body?
Old 05-31-2011, 09:25 PM   #4
Super73
Super73's Avatar
I was running one for about 4 years starting at 402rwhp NA and 3,900lbs, eventually making 449rwhp and 3,650lbs. I was spraying a 100 hit on it no problem (Times in sig). That was a stock 92-93 80E with a 4,500rpm converter. No shift kit, no upgraded clutches, bone stock other than swaping the internal wiring harness to work with the newer style connector. I pulled it to go to a glide due to the reduction of weight and roatating weight. I have yet to take it to the track with the new motor and new trans.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 05-31-2011, 10:38 PM   #5
70shortwide
can i use without electronic controller till i go fuel injected?
Old 05-31-2011, 11:59 PM   #6
Captainfab
60-66 Nut
You can if you switch it over to a full manual.
Old 06-01-2011, 08:14 AM   #7
70shortwide
i dont want a full manual cause when i run the F.I. i will have to switch valve bodies back. i just didnt know if it would shift itself like a 400 or not.
Old 06-01-2011, 01:28 PM   #8
Super73
Super73's Avatar
Your opions are:
Manual Valve Body
Stand alone controller
Factory PCM
After market engine management like the Accel Gen 7 or Big stuff 3
You will not be able to use the linkage to shift it with out some for of electronic controller. Get in touch with this guy http://67-72chevytrucks.com/vboard/member.php?u=22521 He has developed a manual valve body for the 80E as well as an electronic contoller and other items. He will be able to answer many, if not all of your questions.
