Old 05-31-2011, 06:57 PM   #1
norske
Truck "leans" on drivers side.
I've seen some posts where our trucks like to lean towards the driver's side so the driver's looks lower. I have coils, so I picked up some rubber spring boosters from Autozone, jacked up the frame, used a coil spreader tool to spread the coil
(duh), and popped them in. Took about 15 min. Now it looks great going down the road-yippie!
norske is offline   Reply With Quote
Old 05-31-2011, 07:08 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Truck "leans" on drivers side.
what do the rubber boosters look like, and do you have a part number? i might have to give this a try
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 05-31-2011, 07:17 PM   #3
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Does anyone know why they do this? I replaced my rear springs several years ago but the truck still is 3/4"-1" lower on the driver side. Maybe its the fronts?
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 05-31-2011, 07:24 PM   #4
leddzepp
Moderator
leddzepp's Avatar
they all seem to do this. its the chevy lean, lol.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 05-31-2011, 07:51 PM   #5
C/10 King
C/10 King's Avatar
My black truck leans the other way with the passenger side lower, which I prefer because I'm in it by myself most of the time, so it evens out.
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 05-31-2011, 09:04 PM   #6
Shyguy
Junior Member
Shyguy's Avatar
Most auto parts stores have the spring spreaders, some are rubber and some are metal. The metal ones are installed by turning in with a ratchet.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-01-2011, 12:03 AM   #7
norske
I don't have the number handy, will get it tomorrow. If you ask them they'll know what you mean. I'll post a pic also.
Old 06-01-2011, 01:16 AM   #8
67chevy1series
67chevy1series's Avatar
nice one rene!
67chevy1series is offline   Reply With Quote
Old 06-01-2011, 07:15 AM   #9
OJ1988
Just a car guy
OJ1988's Avatar
Check those cab and core mounts for cause of lean
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 06-01-2011, 05:54 PM   #10
norske
Went to take pics and discovered the boosters split in half when I drove it the couple of hundred feet to the garage. Plan B I guess. Maybe the metal wratchet types? We'll see.
Old 06-01-2011, 06:15 PM   #11
oldgold70c10
Who's got steelies?
I had the metal ones in the rear before I got new springs. They just made the ride worse. I think I should have replaced all 4 springs and not just the back, that probably would have leveled it.
My Truck Page
My Youtube Channel
Old 06-01-2011, 07:09 PM   #12
CC69Rat
CC69Rat's Avatar
I have two C10s I plan to lower soon but I also have an S10 that's dropped with 2" spindles and 1.5" springs. The S10s are the same way. About 3/4" on the drivers side.
I used a spring spacer made by Beltech. It is made for the infamous Chevy Lean. It was about $25 bucks, and of course you have to take the spring out but it worked perfectly. I'd highly recommend it, of course assuming the S10 spring and the C10 front coil spring are the same diameter (?) hum .. interesting thought. Just wanted to throw that out there.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 06-01-2011, 08:54 PM   #13
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Mine had a bit of a lean to the left when I bought it. The previous owner had installed a couple of the pot metal twist-in's in the front left spring. When I disconnected the lower control arm from the spindle to install drop spindles and lower springs, I found out why it "leaned"...The spring was broken! PS. As before mentioned, make sure all four cab mounts and supports are good! Springs and mounts are relatively easy and low cost, dont waste time and money on cheap fixes that will ruin your springs and/or a control arm."just sayin"
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 06-01-2011, 10:28 PM   #14
bollybib
bollybib's Avatar
I thought something was screwy on mine so I measured the distance from top-of-frame to bottom-of-cab at the rear of the cab and found a difference of half an inch or so from side to side. Worth checking.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 06-02-2011, 07:24 AM   #15
OJ1988
Just a car guy
OJ1988's Avatar
Bad cab mounts?
1973 Vega Drag Car
1970 C20 tow rig
Old 06-02-2011, 09:17 AM   #16
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
I'am glad someone brought this up, same prob here but I new it would be resolved as soon as my front end rebuild and new cab mounts went in...but no, she still sits lower by an inch at the front drivers side.
Maybe it's like which side you hang...to the left or the right, and Chevy Trucks hang to the left Rene's Truck must be bent...
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 06-02-2011, 09:25 AM   #17
bollybib
bollybib's Avatar
Originally Posted by OJ1988 View Post
Bad cab mounts?
ya i think so. more compressed on driver's side from age and driver weight i'd say. i'll level it out when it starts to cause lack of sleep thinking about it haha.
my vette had serious PS lean. it turned out to be a POS twisted frame so i replaced it. hopefully this is a "worst case" scenario.
- Jim -
Old 06-02-2011, 09:32 AM   #18
eightbanger
454 MAKES IT ROAR
It doesn't fix it! or at least in my case, nor did the front end rebuild as I said...maybe my frame is a little bent from an fender bender in the past.
Nigel.
No more pain.
Old 06-02-2011, 09:44 AM   #19
bollybib
bollybib's Avatar
i don't know the solution, if any. there are a lot of variables that have to be sorted out. but i would think that at least the frame to body dimensions should be equal from side to side.
- Jim -
Old 06-02-2011, 10:18 AM   #20
leddzepp
Moderator
leddzepp's Avatar
this was brought up in a recent thread by smorg007. tweaked frame was the consensus reached since most folks had all new suspension parts and cab/core mounts.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 06-08-2011, 02:12 PM   #21
bollybib
bollybib's Avatar
I should clarify about my "something was screwy" remark in Post #14. What I noticed was that the top of the front of the bed was not parallel with the paint line below the rear window on the cab.
After recently spending time working on my truck with the frame under the bed exposed, it is hard for me to imagine that these rugged frames can be distorted, but they obviously can.
I went back and looked at my photo album of my Vette frame-off that I did back in 1988. This frame is of ladder-type construction similar to our trucks. Back then I made the same assumption as a lot of people have here and first blamed the suspension for the lean, so I rebuilt it and nothing changed. Subsequent investigation led me to the frame. Here are a couple of pics showing the problem that I took back then.
Name:  100_5147 15pct.jpg
Size:  76.0 KBName:  100_5144 15pct.jpg
Here is the link to smorg007's thread on tweaked frames:
http://67-72chevytrucks.com/vboard/s...d.php?t=463980
These "leaner" threads have some good info so I thought it was worthwhile to add my dos centavos.
Peace,
Jim
- Jim -
Old 06-08-2011, 04:47 PM   #22
norske
I'm going to measure frame to the ground on the front. I never noticed it from the front but who knows, it may be leaning the whole length. Will also measure the distance from top to bottom of the springs and see what turns up.
Old 06-08-2011, 06:47 PM   #23
bollybib
bollybib's Avatar
If that is what you suspect, wouldn't hurt to have it checked out by a professional, too.
- Jim -
