85-87 body side molding questions
Looking to remove old yellowing body side molding from my 87 and replacing.
1. Who makes/sells? 2. Any differences in manufactures? I want it correct as possible. 3. Any tips on how to cut to acheive the factory beveled edge? Thanks, Jeff Last edited by JAG66; 05-31-2011 at 09:48 PM. |
Re: 85-87 body side molding questions
I am curious about this too.
I am doing an 87 suburban and haven't had any success re-attaching the factory molding or finding it repro. I could swear I saw it a few years ago as a roll with adhesive backing but can't find it now. |
6.0 powered square
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
you can buy it by the roll from an autobody supply shop
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
JCWhitney sells it. http://www.jcwhitney.com/extra-wide-...85&filterid=j1
Used to be able to find it at Autozone and VIP right on the shelf, but I havent looked lately and these trucks are getting older, so they probably don't anymore. But you could ask, they could probably get it for you. I've done it once before, and plan on doing it again with the new truck. Helps to lay it out in the sun to soften it up and take the roll out of it, or it will just want to spring back into the shape it was in the roll. I don't remember doing anything special about beveling the edges, I think I cut it with a whiz wheel. You will have to re-use or get new corners, this stuff wont bend that way. I mean the clip-on corners right under the taillights. Snap a chalk line to give you a straight place to work on, and pull the tape backing out a bit at a time, so as you stick one end down, you pull the backing out a little farther and stick a little more of it to the truck. Instead of peeling all the backing off at once and having no adjustment as you go along if you get a little crooked.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop. |
Classic parts also sells it, here is the link.
http://www.classicparts.com/Trim-Har...ducts/403/12/0 |
Diggin The SquareLife
i ordered my from lmc..good stuff
I just noticed LMC also has it in a precut package. if you're not poor like me that seems like a real timesaver.
The precut set from LMC is really nice. Makes life alot easier...well for me anyway.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
I used the LMC pre cut parts.
You can check out my installation in my build thread (linked below - page 6 post 142, and page 8 post 198). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 06-02-2011 at 08:11 AM. |
