03-30-2003, 10:49 PM | #1 |
Pic of linkage?
Can someone post a pic of their clutch linkage with a v8. I converted a 6cyl to a 8 cyl and having trouble what to buy. I beleive I need the z bar for the 8cyl. If I could just see a pic of someones that would help a lot. Thanks Brian Wolf
03-30-2003, 11:00 PM | #2 | |
Re: Pic of linkage?
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
03-30-2003, 11:07 PM | #3 |
When I took off the the linkage the first time on the engine there was a funny looking bar with two bolt holes and it was like u shaped. That bar doesnt bolt to the v8. What do you have bolted to your engine holding the z bar. Thanks
03-30-2003, 11:11 PM | #4 |
Recovering 67-72 Addict
There is a pivot ball that threads directly into the block.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
03-30-2003, 11:19 PM | #5 |
I have learned that the bracket on the frame is diffrent from L6 to a V8. Then of course the bracket on the engine will be diffrent. I do belive that the Z-bar it self should be the same from 6 to8.
03-30-2003, 11:49 PM | #6 |
NOT SURE IF THE Z BARS ARE THE SAME BUT THE GUYS ARE RIGHT ABOUT THE PIVOT BALL. THERE SHOULD BE A THREADED HOLE ON THE SIDE OF THE BLOCK THAT THE PIVOT BALL SCREWS INTO.
03-31-2003, 12:13 AM | #7 |
Brian, Stop over sometime if you get a chance. I have the full stock clutch linkage set up and my sb is out so you can see what you need.
Drop me a PM.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
04-03-2003, 12:07 AM | #8 |
Progress = 0%
Hey Brian! Long time, no see! Sorry to change the subject, but here's a picture for you......
Look familiar??? If not, let me refresh your memory..... I bought a set of the below pictured hubcaps from you. They turned out to be the wrong ones. You told me you'd refund my money if I sent them back. I sent them back and I've never seen my money. Your dad even told me he'd send me the money.........still haven't seen it. Have you been able to save up $60 since then???? If so, I'll give you my address and you can drop a check in the mail. Oh sorry, I can't help with your clutch linkage problem
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
04-03-2003, 05:47 PM | #9 |
Progress = 0%
TTT
04-03-2003, 07:01 PM | #10 |
Fabricate till you "puke"
the Z bars are different from 6 to 8, as are the rods, & frame bracket. The V8 sb in factory position , has a bracket with 2 holes that bolts to the block with the pivot ball welded on(2 wd). I have run the V8 linkage , with the sb in I 6 position, & used a screw in pivot ball in the foward hole in the block, redrilled the holes for the frame bracket to keep the Z bar perpendicular with the eng, & changed the lenght on the bottom rod. The top rod from the peddle arm to the Z bar on the 6 is straight.......the sb rod has a couple curves in it to set it away from the eng....crazyL
05-28-2003, 04:09 PM | #11 |
Progress = 0%
Hey Brian,
You still owe me $60.00!!! Pay up!
