Old 05-31-2011, 10:19 PM   #1
longblue72
Active Member
2 barrel rochester deal
Got a to barrel feeding my 350. idles fine and starts up good and all, but when I go to give it gas, it bogs down. Pops told me it was the accelerator pump. So when I go to replace this, should I remove the whole carb? Or take off the top half and replace it from there. Im just wondering whatever was easiest for one of you guys.
Thanks!
longblue72 is offline   Reply With Quote
Old 06-01-2011, 07:01 AM   #2
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Re: 2 barrel rochester deal
For a quick fix like that, I usually just take the top part off. As long as your comfortable doing that (hanging over a fender) LOL then go for it.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 06-01-2011, 02:47 PM   #3
truckster
truckster's Avatar
It kind of depends. What's the overall condition of the carb? In my experience, by the time an accelerator pump needs attention, the whole carb could use at least some cleaning and gaskets.
truckster is offline   Reply With Quote
Old 06-01-2011, 04:29 PM   #4
longblue72
Active Member
well i was gonna do what bob said and just replace the accelerator pump, but now my dads gonna take it and 2 other carbs to get rebuilt.
Old 02-18-2012, 11:26 PM   #5
longblue72
Active Member
bringing this thread back to life, I got the carb rebuilt, and its doing the same thing, if I were to mash the gas, it just wants to bog down, then fire up. would that be my timing thats off? what would I need to do to correct this bogging?
Old 02-19-2012, 06:17 AM   #6
MikeyMan
Check & inspect your fuel lines and fuel pump.
I have heard of instances where a rubber hose will collapse and restrict fuel supply.
MikeyMan is offline   Reply With Quote
Old 02-19-2012, 06:44 AM   #7
rsavage
rsavage's Avatar
Timing could be the issue.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 02-19-2012, 10:26 AM   #8
68gmsee
Active Member
68gmsee's Avatar
Need more info.
What year engine?
How many miles on the engine?
Have you replaced any ingnition parts like points, plugs, rotor, cap, etc?
HEI or points distributor?
When it bogs does it bog during normal acceleration or only on rapid acceleration?
68gmsee is offline   Reply With Quote
Old 02-19-2012, 02:47 PM   #9
longblue72
Active Member
I guess year would be a 72
87,653 miles or close to that
Replaced plugs and plug wires
points distributor
And it seems too occur at both types accelerations, id have to come back on tonight and really make sure if it is both
Old 02-19-2012, 05:04 PM   #10
Wrenchbender Ret
With the engine off, look down the throat of the carb & work the throttle linkage. You should see 2 squirts of gas going into the throat each time. If so the accel pump is working OK. If it is just a dribble your pump is still not working.
Try setting the timing up a little. It is possible the float level is low. The carb may have been changed at one time & the main jets are too small.
Wrenchbender Ret is offline   Reply With Quote
Old 02-19-2012, 05:57 PM   #11
68gmsee
Active Member
68gmsee's Avatar
Check the above and also make sure you are using manifold vacuum. The vacuum line below the throttle butterfly valves.
While you're at it, using mouth suction, see if the vacuum advance moves freely, the points are at around .019 at the high point of the cam and the distributor weights also move freely.
Old 02-20-2012, 10:39 AM   #12
longblue72
Active Member
So that bog is a backfire up the carb. timing?
