Old 05-31-2011, 10:30 PM   #1
67camarors
1975 Chevy 3/4 Ton 8 Lug Wheels Question
I have a 1972 cheyenne 3/4 ton with the original split rims and I want to buy some regular 16 inch wheels to put on there. they need to be 16 inch, not 16.5
my question, what year model trucks had the 16 inch and which had the 16.5?
thanks
67camarors is offline   Reply With Quote
Old 05-31-2011, 10:53 PM   #2
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Re: 1975 Chevy 3/4 Ton 8 Lug Wheels Question
Not sure of your answer, but the previous owner of my '73 K20 said it originally had 16.5 steel wheels and he didn't like the oddball size so he put 16" wheels on it, which coincidentally are Ford wheels. They fit great. I know this doesn't answer your question, but at least it may give you other options. If I'm not mistaken, they look like they came off a van.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 06-01-2011, 12:38 AM   #3
DetroitDan
DetroitDan's Avatar
split rims? on a 3/4 ton?
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
Old 06-01-2011, 09:23 AM   #4
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
makes you feel better my 84 dually has 16's front and 16.5 out back :S sorry i can't help but thought i would share
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 06-01-2011, 06:46 PM   #5
str8axle55
My 86 K30 SRW, has 16 in wheels, as does my 88 Suburban, as did my 82 K20. I had a set of F*rd wheels on for the winter, they were the grey one`s you see on vans all over. I think the F*rd wheels are 7 in wide, and I know my Chevy wheels are 6.5 in wide. Hope this helps.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 06-01-2011, 11:32 PM   #6
azjaeger
azjaeger's Avatar
My 75 3/4 ton 8 lug had 16.5 wheels on it, I replaced them with 16 inch 02 Express Van wheels...worked fine.
azjaeger is offline   Reply With Quote
