06-01-2011, 07:33 AM | #1 |
Just a car guy
3"/5" drop, front higher
Just got my rear springs in and now my front is sitting 1/4" higher.
Used cpp springs. I am adding the adj rear track bar which will lower the rear another 1/4". Aldo swaping to a blazer tank which will put more weight on the rear. Someone said , "let the springs settle" the fronts have been in the truck for almost 6 months. If anything "settles" I only see the rear going lower. So my options are? 1. Cut front springs 2. Swap to 2" springs and drop spindles? ( costly) or? Posted via Mobile Device
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
06-01-2011, 08:30 AM | #2 |
Re: 3"/5" drop, front higher
I've heard this alot from CPP products. I would be afriad cutting the front springs any more would cause problems. I would do a spindle/1" spring drop in front. Have you already converted to disc brakes?
06-01-2011, 08:59 AM | #3 | |
I would go with #2 or at least the 2" drop springs.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
06-01-2011, 09:40 AM | #4 |
get larger rear tires
06-01-2011, 09:59 AM | #5 |
06-01-2011, 01:29 PM | #6 | |
06-01-2011, 03:18 PM | #7 |
Just a car guy
Yes I have converted to disc,
as for tires I have new tires all around and want the same size for rotation, spare and speedo purposes. Before I had cut stock springs in the front and it sat lower and rode ok, I'm thinking 1/2 coil off the front would get me there. Posted via Mobile Device
06-01-2011, 03:35 PM | #8 | |
06-01-2011, 03:47 PM | #9 |
Moderator
cutting half a coil will yield approx 1" drop, a full coil 2" drop.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
06-14-2011, 07:19 AM | #10 |
Just a car guy
Here it is with 3" fronts and 5" rears.
06-14-2011, 07:19 AM | #11 |
Just a car guy
06-14-2011, 09:09 AM | #12 |
I suggest a spindle/spring drop.
06-14-2011, 09:32 AM | #13 |
its all about the +6 inches
cut a 1/2 coil, it'll be fine.
06-14-2011, 12:41 PM | #14 |
Project Junkie! Fishing Poor!!
I wouldn't cut any more spring out of the front. You notice nobody sells 4" front lowering springs. That is because the spring will rattle around in the pocket. 3" is max and I advise my customers not to even do 3" because I feel the spring is too short. I would go to a drop spindle and 1" front lowering springs. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 06-14-2011 at 12:41 PM. |
06-14-2011, 12:50 PM | #15 | ||
"I ain't nobody, dork."
Stance looks good to me!
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
06-14-2011, 01:06 PM | #16 |
Just a car guy
None has been cut from the front in those pics.
I have cut a half coil off and will get pics posted. The rear is coming down another 3/8" due to the cpp long track bar installation. With the old cut stock springs the front sat about 1" lower than it does now. The ride was acceptable to me. I'll post pics in the next day or so with the 1/2" coil cut front. Posted via Mobile Device
06-14-2011, 01:07 PM | #17 |
Just a car guy
Drop spindle and a 1" spring would put me where I am now. I need a drop spindle and a 2" spring, or bags I guess
06-14-2011, 08:42 PM | #18 |
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
06-14-2011, 08:59 PM | #19 |
laying low
Where are you measuring your drop? Center of fenderwells? You know they measure different from the factory right? Did you put on lowered shocks too? Everybody has their own tastes ya know but I'd raise the rear up an inch and drive the wheels off of it. It'll take the bumps and potholes better if you don't go any lower in the front. JMO
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
06-14-2011, 09:37 PM | #20 |
Just a car guy
I want a little more rake. It was lower in the front before will stock shocks and cut springs. I drove it everyday and if wasn't bad to me, the rear was worse, it had heated coils and only one or two worked!
Yes I am measuring to the wheelwell center. I am comparing to the measurements before. It sits lower in the rear then before but a little higher in the front, then before, cut one half coil on one, still got to do the otherside. Yes I added drop shocks. Toxic shocks front and rear. Added shorter poly bumpstops as well. Front also got shock brackets, '78 a arms, spindles, steering links, all new, new balljoints, poly bushings, 1.25" sway bar. Rear I am adding the cpp long panhard bar, shock relocating mounts. I am use to driving camaros with stiff springs. Posted via Mobile Device
06-14-2011, 09:50 PM | #21 |
Cruzin
you could always add a bigger/heavier motor/ i think it looks good now but do it till it pleases you.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
06-16-2011, 05:25 PM | #22 |
Just a car guy
Here it is with a 1/2 coil off the front.
06-18-2011, 03:13 PM | #23 |
Just a car guy
What do you think?
06-18-2011, 03:17 PM | #24 |
Champagne Taste on Beer Budget
I like it!
So how does it ride now?
Coming Soon: Project 1970 Country Truck |
06-18-2011, 03:40 PM | #25 |
Just a car guy
Not quite ready to road test bur will let you know as soon as I do!
