Old 06-01-2011, 02:57 PM   #1
creep
Registered Loser
creep's Avatar
Radiator?
I need a good radiator to cool the 383 in my 63 GMC. Right now I'm still using the stock radiator for the 305 V6 but it's not doin' the job now that the weather is getting nicer and summer temps are creeping in. I would like something that's pretty close to the stock rad size. Any suggestions?
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 06-01-2011, 03:24 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Radiator?
look on EvilBay, I got an aluminum one that also came with a dual electric fan.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-01-2011, 04:06 PM   #3
onequickchevy
onequickchevy's Avatar
Re: Radiator?
+1 on that. Mine was a little over a hundred bucks and it keeps my 40 over heavily cammed high compression small block at 180 in traffic.
Slowly but surely getting it done.
onequickchevy is offline   Reply With Quote
Old 06-01-2011, 05:31 PM   #4
creep
Registered Loser
creep's Avatar
Re: Radiator?
Thanks guys, will do. Any idea what dimensions to look for?
Old 06-01-2011, 05:35 PM   #5
66GTO66C10
66GTO66C10's Avatar
Re: Radiator?
I am running a Champion aluminum 4 row that cools great. Here is a link to one probably compatable for your truck. Good luck.
http://cgi.ebay.com/ebaymotors/1963-...item3cb52f4051
1966 Chevy C10 frame off resto (In progress)
1966 GTO Numbers matching original
1989 Toyota Pickup (Tonka) resto
2002 HD FLSTC
2000 HD FLSTC
1996 Ninja ZX11
Believe nothing of what you hear, and 1/2 of what you see!
66GTO66C10 is offline   Reply With Quote
Old 06-01-2011, 05:54 PM   #6
creep
Registered Loser
creep's Avatar
Re: Radiator?
Yeah, I was looking at that one and this one...
http://cgi.ebay.com/NEW-Aluminum-Rad...item5ae0cb373b
Is there a performance difference between crossflow and downflow?
Old 06-01-2011, 06:28 PM   #7
Clyde65
Clyde65's Avatar
Re: Radiator?
creep, if you buy them that are specifically for the 63-66 then your good.
Clyde65
Rebuild of Clyde
support our troops!
Old 06-01-2011, 10:57 PM   #8
towersddg9
towersddg9's Avatar
Re: Radiator?
I have a champion from ebay looks good cools good
towersddg9 is offline   Reply With Quote
Old 07-07-2011, 11:47 AM   #9
enick72
enick72's Avatar
Re: Radiator?
have any of you guys used an electric cooling fan, if so what size and pics
55 Chevy 1st series
65 Chevy stepside short bed
www.bigslikpokertables.com
enick72 is offline   Reply With Quote
Old 07-07-2011, 12:30 PM   #10
Clyde65
Clyde65's Avatar
Re: Radiator?
I dont have pics but I have two 12" electric fans. one comes on at 180 and the other comes on when the AC comes on or 200. I also have the Champion aluminum 3 core rad.
Clyde65
Rebuild of Clyde
support our troops!
Old 07-07-2011, 12:56 PM   #11
1enick72
1enick72's Avatar
Re: Radiator?
Did you build a shroud or did you buy it as a unit?
1enick72 is offline   Reply With Quote
Old 07-07-2011, 01:42 PM   #12
Clyde65
Clyde65's Avatar
Re: Radiator?
it has no shroud, I wish I had one, just to increase the effectiveness.
Clyde65
Rebuild of Clyde
support our troops!
Old 07-08-2011, 01:02 PM   #13
bama63
bama63's Avatar
Re: Radiator?
creep Is there a performance difference between crossflow and downflow?
only a slight difference, the cross flow circulates at a slightly slower rate because the water pump has to push the water up to the upper part of the radiator and therefore cools a little more efficiently, but you would only see a slight difference of a couple of degrees
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 07-08-2011, 01:51 PM   #14
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Radiator?
Check this one out.
http://cgi.ebay.com/ebaymotors/RADIA...Q5fAccessories
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 07-08-2011, 02:05 PM   #15
scum1
scum1's Avatar
Re: Radiator?
not to hijack creep...but im also looking to keep cool during the summer was considering electric fans but did some searches and most said stick with mechanical and shroud...im not sure how hot it is in ohio during summer but vegas gets pretty hot obviously. has anyone ran a mechanical puller on engine side and an electric pusher on the other?? would that work? what are you guys who live in the hot weather use on your mild setups? btw those radiators dont look bad, i know mine is probably an old original
scum1 is offline   Reply With Quote
Old 07-08-2011, 03:07 PM   #16
Clyde65
Clyde65's Avatar
Re: Radiator?
I think it is a choice there Scum1, it would work either way IMO, the mechanical fan would steal a bit of HP, where the electic fans wouldnt.
Clyde65
Rebuild of Clyde
support our troops!
Old 07-08-2011, 09:43 PM   #17
creep
Registered Loser
creep's Avatar
Re: Radiator?
I had a mechanical puller with a homemade shroud and an electric pusher on the stock radiator and it got really hot. I switched to an aluminum radiator and dual 13" electric pullers with shroud and it stays around 180-190 degrees now.
Old 07-08-2011, 09:46 PM   #18
creep
Registered Loser
creep's Avatar
Re: Radiator?
Here's what I used...
Old 07-09-2011, 10:11 AM   #19
Clyde65
Clyde65's Avatar
Re: Radiator?
Creep, where'd ya get the electric fans and shroud?
Clyde65
Rebuild of Clyde
support our troops!
Old 07-09-2011, 05:10 PM   #20
creep
Registered Loser
creep's Avatar
Re: Radiator?
They are made by Derale and I got them at Summit Racing.
Old 07-09-2011, 05:45 PM   #21
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Radiator?
i got a brand new griffen radiator sitting here TR/LL outlet for chevy
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-09-2011, 11:21 PM   #22
Mechanic77
Re: Radiator?
Just to throw out another electric fan option...you might consider a Lincoln Mark VIII fan....18" fan that some claim moves 3500+cfm, although it does pull 30+amps too.
If you watch ebay, you can pick one up for under $100.
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627
Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948
Mechanic77 is offline   Reply With Quote
