Need help quick
I just had my starter worked on and put it back on. When I turn the key I gt nothing. Last night before I took the starter off It was doing fine. So what have I shorted out. I get nothing when I turn the key. I get no power to anything. It a 85 k30 with a 454.
Slots go on anything!
Re: Need help quick
Sounds like it might be a bad ground. Can you look at the voltage gauge while trying to crank? If it comes up, then goes all the way to the left while cranking, is usally the sign of a bad ground.
1974 Jimmy- 5.3/4L80e/NP241 |
Chevys Kick A$$
Re: Need help quick
I don't think you shorted anything out unless you left your battery hooked up when you took it out. I am pretty sure its not getting a good connection that would cause you to have no power I believe!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
Re: Need help quick
yea i feel pretty stupid but I forgot to unhook the battery when I took it off. And I think that caused problems. Where should I begin to look.
Re: Need help quick
Do you have working headlights, horn, etc.?
Do you have a voltmeter? Did you hook up the solenoid wrong? Measure the voltage at the solenoid to ground where the purple wire connects. I'm not certain its purple on a 73+ but the wire from the ignition switch. Is the above wire on the S terminal of the solenoid? |
![]() Join Date: Sep 2010
Re: Need help quick
check the fusible link maybe you fryed it when you took the starter out with it still connected
1985 c10 355 th350 (working on 4 speed conversion to super t10) 1979 camaro 358 super t10 2003 f250 superchip slp exhaust |
Re: Need help quick
where is the fusible link. I am getting absolutly no power anywhere and these are two brand new baterries. Some pictures would help my dumb butt alot.
#8 | |
Re: Need help quick
The fusible links were down by the starter on early models (pre-HEI) & then IIRC they were moved up to the firewall on the post HEI trucks.
Re: Need help quick
which wire am i looking for this on. It is a 85 model with a 454. Any pics would be nice.
Re: Need help quick
Ok, I finally realized I didn't have the positive battery cable hooked up, but I did get all the wires cleaned and straitened up and put up neatly. Thanks for the help.
Posted via Mobile Device |
#11 | |
Gentleman Jim owner x2
![]() Join Date: Oct 2010
Re: Need help quick
![]() Don't worry, I've done stuff like that before, too. Glad it worked out.
1975 GMC Gentleman Jim #1 -357 / 700r4 1975 GMC Gentleman Jim #2 -350 / TH350 |
