Old 06-01-2011, 07:38 PM   #1
bosco200
bosco200's Avatar
Very frustrated
Ok some of you may know the story about my wiring getting fried....if you havent here it is....http://67-72chevytrucks.com/vboard/s...ght=fry+wiring
Ok so we got all the wiring done....everything works, except for my truck starting.....I thought it might be the igntion....got a new one, didnt fix it....ACC works, on works, but when I go to start it.....nothing, the only thing that happens is the break light on my gauges comes on, but its always done that when ive went to start it....I got the starter and solenoid checked...they passed....we tryed to by pass the ignition and tried to jump the solonoid and starter nothing.....the starter doesnt even budge....can anyone help me out here?
bosco200 is offline   Reply With Quote
Old 06-01-2011, 08:41 PM   #2
Re: Very frustrated
See if you get power to the starter would be my first check.
Even though you jumped the main lead,the starter may not have any juice from the ignition lead.
Also, Can you turn the engine by hand?
Old 06-01-2011, 08:51 PM   #3
BlazinC5
BlazinC5's Avatar
Re: Very frustrated
Check the neutral safty switch too. I at one point managed to bump mine and didn't know I put it out of adjustment. park and neutal no worky, but rev. and drive it would start. I felt like an a$$ after a few days of testing wires and forgot I moved the lever into drive and turned my key to discover this...
71 2wd Blazer
My build, Restarted
05 Buell firebolt
94 1500 Z71
No rice for me,,, I'm full
BlazinC5 is offline   Reply With Quote
Old 06-01-2011, 10:02 PM   #4
jamie72
jamie72's Avatar
Re: Very frustrated
try that... move you shifter up and down a little while bumping it over..
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 06-02-2011, 02:23 AM   #5
dmack91
dmack91's Avatar
Re: Very frustrated
Is there a chance there is a fusible link in the wiring to the starter?
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 06-02-2011, 09:57 AM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Very frustrated
Do you have the wire on the correct post of the starter solenoid? Not the hot wire from the battery... but the wire that comes down fronm the engine harness.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-02-2011, 11:18 AM   #7
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Very frustrated
It has got to be the neutral safety switch if you have replaced the switch and it still gives you nothing, not even a bump on the starter.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-02-2011, 12:26 PM   #8
yuccales
yuccales's Avatar
Re: Very frustrated
Gary
Check this. Good luck in getting it running.
yuccales is offline   Reply With Quote
Old 06-02-2011, 03:04 PM   #9
bosco200
bosco200's Avatar
Re: Very frustrated
Thanks for all the replies guys....my trucks a manual so there is no neutral thing ur talking about....yes theres a fusable link Ive changed it already....but im looking a a wiring diagram and it shows another fusable link in the wire close to the battery ill have to check that to.
Old 06-02-2011, 03:28 PM   #10
Clyde65
Clyde65's Avatar
Re: Very frustrated
I dont know if your truck has one but there is a trigger switch for the manual shift trucks, I think it is close to the shifter, maybe that is only for the 4speed. I read this on another thread so I am just spewing what I read.
Clyde65
Rebuild of Clyde
support our troops!
Old 06-02-2011, 04:40 PM   #11
bosco200
bosco200's Avatar
Re: Very frustrated
Mine is a four speed...where is this trigger switch?......O I also hooked battery cables to the battery and took my starter off, and I got the gear to jump up once but then after that it wouldn't do it anymore.
Old 06-02-2011, 05:08 PM   #12
dmack91
dmack91's Avatar
Re: Very frustrated
Don't know on this trans, but it should be a switch that it incorporated (threaded) into the trans (kind of like a reverse light switch), possibly near the shifter linkage.
I would look around the trans and try to find an electrical plug/wiring that is going to it. If there is one, it is probably a back-up light switch. If there are two, one would probably be a neutral switch.
Just a guess though.
Old 06-02-2011, 05:24 PM   #13
archie307
Re: Very frustrated
"I also hooked battery cables to the battery and took my starter off, and I got the gear to jump up once but then after that it wouldn't do it anymore."
Don't you to take this the wrong way but, is your battery fully charged? I often overlook the simplest things.
archie307 is offline   Reply With Quote
Old 06-02-2011, 11:20 PM   #14
bosco200
bosco200's Avatar
Re: Very frustrated
Lol well i hope its fully charged...ill put it on the charger tomarrow....and yes there is a plug in that goes down my trans but its for my back up light....but there is also this one that is really thick....but its so oily and dirty down there i cant tell if thats it....it goes straight into the left side
Old 06-02-2011, 11:20 PM   #15
jocko
jocko's Avatar
Re: Very frustrated
When you took the starter and solenoid off the truck and applied juice - does the solenoid kick to engage and then the starter doesn't spin? or does the solenoid leg not even kick to engage?
Either could be due to low batt - but if you're checking it with a fully charged battery (like from another running car or something) then I would replace the solenoid.
Agree with all other comments - ESPECIALLY the neutral safety switch - fell into that trap myself once, almost ripped my hair out after a rapid weekend rebuild one weekend to make it to work on Monday - and after wasting about 36 hours, I shifted into Park, and vrooom. Wanted to scream. Anyhoo - if you are bench testing the starter and solenoid OUT of the truck with a good battery, and it still no workie, then I think you've found your problem - because that takes all the other possibilities out of the loop.
Old 06-03-2011, 02:37 AM   #16
dmack91
dmack91's Avatar
Re: Very frustrated
Just a guess, but the thick one is probably the speedo cable.
Old 06-04-2011, 01:30 PM   #17
bosco200
bosco200's Avatar
Re: Very frustrated
Ok I checked for the neutral switch on my tranny, I could not find it all I found was my speedo cable and back up lights, It s SM465 if that helps, but I also figured out that when I turn my key to on or ACC, Ill turn my fan on and when I pull my lights to come on, the fan slows down a whole bunch.
Old 06-04-2011, 02:58 PM   #18
bosco200
bosco200's Avatar
Re: Very frustrated
O also there is a brown wire from my ignition that goes through the fire wall through that fuse plug in, and it has a little plug in thing on the end of it but there is nothing to plug it into, there is also 2 plug ins under the dash, one has a light and dark green wires, and the other one has 2 big purple wires and I have no clue what they are for.......my dad had an automatic transmission in his could those have to do something with that neutral switch?
Old 06-04-2011, 03:48 PM   #19
bosco200
bosco200's Avatar
Re: Very frustrated
Ok heres a pic of the brown wire that I have no clue what it plugs into...its starts at my ignition and goes through the fuse box and then through the big plug in, then into this tiny plug in and I don't know where it goes.
Old 06-04-2011, 04:59 PM   #20
john
member #16
john's Avatar
Re: Very frustrated
These are the N/S sw. wires and probably your problem. The purple wires are the starter circuit and the green the B/U light wires.
john is offline   Reply With Quote
Old 06-04-2011, 05:51 PM   #21
bosco200
bosco200's Avatar
Re: Very frustrated
So what should I do with them then?
Old 06-04-2011, 06:38 PM   #22
john
member #16
john's Avatar
Re: Very frustrated
If you tie the purple ones together it should start. It will start in gear is the only downfall. The green ones you can extend to the trans b/u light sw.
Old 06-04-2011, 07:15 PM   #23
bosco200
bosco200's Avatar
Re: Very frustrated
The 2 purples are in the same plug...hang on ill go take a pic real quick.
Old 06-04-2011, 07:20 PM   #24
bosco200
bosco200's Avatar
Re: Very frustrated
Ok here it is....and ive always been able to start it in gear....its a manual
Old 06-04-2011, 08:58 PM   #25
pops45
Junior Member
pops45's Avatar
Re: Very frustrated
What happened when you did this:
"When you took the starter and solenoid off the truck and applied juice - does the solenoid kick to engage and then the starter doesn't spin? or does the solenoid leg not even kick to engage?"
If you apply power directly to the starter, bypassing everything, and it does not spin then you need to get the starter tested. You need to get this working before you continue. After that look at some of the wiring diagrams on the forums and make sure everything else is wired correctly. You should do this systematically, one step at a time, from the ignition key switch and trace power out to the starting circuit.
pops45 is offline   Reply With Quote
