NP-203 Pics
I'm getting ready to convert my 83 shortbed 4x4 to a manual and the transfer case I have to use is an NP-203. Can someone post a pic of how it's mounted up in the truck? What type of x-member is used? Any help will be greatly appreciated. Thanks.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
Re: NP-203 Pics
The sm465 to 203 was only offered I beleive from 1973 to 1974 so the adapter is rare .I beleive there is a complete tranny and transfer on E-bay right now(search for 203 transfer case in the parts section).I beleive Off Road Design has a write up on different ways to connect the 465 to the 203 on their website.Why do wou have to use a 203?
Re: NP-203 Pics
I'm using the 203 because it's what I have. I did an inventory of what I would need for the conversion and all I have to buy is some bolts and driveshafts. The t-case is already bolted to the transmission, I just don't know what the crossmember looks like. There is a bracket on the t-case and I think that is all I need but I want to be sure.
Re: NP-203 Pics
this work??? its a 1976 chevy 1\2 ton with a t350\203
![]() ![]() the drive shaft is coming from the front so the tcase mounts on the back holes.
chevys the way to go. ![]() ![]() Last edited by alwaysbroken; 06-03-2011 at 01:42 AM. |
Re: NP-203 Pics
Awesome thanks!!! I was thinking mine might be different because I'm using a manual transmission.
Re: NP-203 Pics
in mine the trans just floats.
chevys the way to go. ![]() ![]() |
