Old 06-02-2011, 12:41 AM   #1
del
locking door from inside with altman kit
For those of you who installed the altman/trique lock kit, how do you lock your doors from the inside. I tried everything I can think of, but can't get it to work. This is for a 1959 chevy apache. Thanks
del is offline   Reply With Quote
Old 06-02-2011, 07:49 AM   #2
entourageguy
Yellow truck club
entourageguy's Avatar
Re: locking door from inside with altman kit
did you check with them? I see to think that with this kit you can't.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 06-02-2011, 11:30 AM   #3
del
I just found out you can't. I was just wondering if anyone else has done some modification to make it work. Thanks
Old 06-02-2011, 08:03 PM   #4
BlueJeep
BlueJeep's Avatar
Best thing I've come up with is to use an electric solenoid, either their kit or some other and have a wireless remote. I think that's what they told me too.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 06-03-2011, 09:51 AM   #5
duwem
duwem's Avatar
Are you guys talking about the Bear Claw kit?
Here is the installation instructions:
http://app4.websitetonight.com/proje...structions.pdf
"No Altman Easy Latch Kit will allow you to lock your door by pushing forward on the interior
handle. It is advised to use electric lock actuators or fabricate your own lock rods."
duwem is offline   Reply With Quote
Old 06-03-2011, 02:13 PM   #6
del
I now know that about the lock. I was wondering ,though, if anyone did fabricate some kind of rod to lock from the inside. Thanks
Old 06-04-2011, 10:43 AM   #7
skip99
skip99's Avatar
I did it with bear claws, you might use the same technique with altmans. in my build..
used the original strap, just elongated the hole to make it slip in one direction. and lock the other..
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 06-04-2011, 11:19 AM   #8
del
I tried to do that and cut a large slit, but it didn't work.
