Old 06-02-2011, 12:21 PM   #1
99-LS1-SS
99-LS1-SS's Avatar
Adding A/C to the truck and need to know what I need
Is there a "laundry list" of parts that I will need to add A/C to a truck that didn't come with it? I'm getting a new compressor when I get the motor so whatever I do will need to hook up to that.
Thanks for any help.
99-LS1-SS is offline   Reply With Quote
Old 06-02-2011, 12:45 PM   #2
48richard
48richard's Avatar
Re: Adding A/C to the truck and need to know what I need
I added AC to my truck a year ago, and have a complete list of the parts needed; I'm away from home until Sunday, but if nobody else comes up with one, I can send it to you then.
Richard
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 06-03-2011, 01:24 AM   #3
jimmypop
Sub
jimmypop is offline   Reply With Quote
Old 06-05-2011, 08:09 PM   #4
72clifblazer
72clifblazer's Avatar
please post as I will needit to
72clifblazer is offline   Reply With Quote
Old 06-06-2011, 12:57 AM   #5
48richard
48richard's Avatar
This is the list of parts I came up with:
A/C balls
Center vent
Center vent adaptor
Center vent gasket
Control cables
Controller
Hoses A/C air
Hoses defroster
Defroster vents
Compressor
Compressor mounting
Crankshaft pulley
V-belt
Condenser/Receiver/Dryer kit
Evaporator
Evaporator/Blower housing (large underhood box)
POA valve
Expansion valve
Refrigerant hoses and pipes
Heater core
Heater hoses
Heater seal kit
Vacuum operated heater water valve
Controller light
Switch - blower
Switch - Compressor clutch safety
Wiring harness
A/C distribution box
Defroster distribution box
Heater box
S-duct (these last four are the boxes under the dash)
Vacuum actuator - Kick Panel air valve
Vacuum actuator - Plenum air valve
Glovebox
Plenum air valve
Vacuum reservoir
Miscellaneous brackets and clips
Hope this helps.
Richard
Old 06-06-2011, 04:48 AM   #6
99-LS1-SS
99-LS1-SS's Avatar
Thanks Richard.
Old 06-06-2011, 05:21 AM   #7
85_C10_Sleeper
85_C10_Sleeper's Avatar
I just pulled my a/c off my 85. PM me what you need and ill let you know what i still have.
85 C10 LWB
305ci - 700r4 - 10 bolt - 3:08 gears
Collecting parts for a 'mild prerunner"
85_C10_Sleeper is offline   Reply With Quote
