1968 327 and TH400
For sale. $900. Out of 68 C20.
Engine rebuilt about 2000 miles ago. I replaced with 5.3 and 4l60e. Came out of 68 C20 Custom Camper. Tranny cleaned up, new front and rear seal, filter and fluid. Ran good when pulled, just wanted more towing power and MPGs. Rochester quadrajet rebuilt by me. Comes with HEI distributor, original distributor. Has new spin on filter adapter. includes new headers, water pump. Numbers on block, 13 GM 3914678 at back drivers side.Back passenger side, 3 D10 8. Front of passenger head on block,V0423YV. Intake, C27 8. 3818803 GM1. Thanks. Will supply shift linkage and original distributer and miscelaneous? other parts if wanted. |
Re: 1968 327 and TH400
Pics
10/30/19
Are you coming to teeitups meet in Meridan Kansas?
Fight the good fight, finish the race, keep the faith |
I'm interested in more info on the rebuild and what all was replaced and checked.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
No, not making it to Teeitups. The engine was rebuilt by Precision Engine rebuilding in Russellville Ar. Rebuilt to stock spec.s. As far as I know the cam, bearings, freeze seals, timing gears and chain, oil pump, lifters and rings replaced.I don't recall if pistons replaced. Heads rebuilt.New water pump, HEI distributor. Comes with AC compressor that was working with R12 when removed. Alternator with both header and original brackets. Also old canister oil filter housing and old disributor. All new plugs and wires. I put about 2000miles on the engine after rebuild before replacing with my 5.3. It does have a drip( like 2 or 3 drops over night) from oil pan I believe. The tranny was working when removed as well. I replaced front and back seals, but not the big pump o-ring in front. Has light leakage from there I believe. I replaced filter and fluid on tranny after engine rebuild. Don't know if tranny was ever rebuilt or not. Pan had some silt in it when I opened it up to change filter. Thanks. Jim
Has original fuel pump and starter also.
Buy it Keith, so you'll remove the temptation from me!
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
I should have this on a test stand and at the PettyJean car show this weekend. Anyone gonna be there? Thanks
![]() Join Date: Jun 2005
Will you split the engine and trans up?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#11 | |
![]() Quote:
1987 350 TBI lowered 5/7 |
I might try to run up to Petit Jean...temptation is a terrible thing.
#13 |
I will be at the Petit Jean show...we are leaving out early on the 16th. Maybe I'll run into you up there.
#14 |
id love to have it but its almost a 10hr drive for me
1965 c10 short stepside ![]() 1967 c10 fleetside 350/350 trans (my baby) |
#15 |
do you know if hardend seats were installed in the heads?
Doug Looking for a 67-72 short bed driver..... |
#16 |
![]() Join Date: Sep 2002
would u consider shipping them?
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
#17 |
No, not going to WV anytime soon. I'm going to try and sell first as a unit, since its so complete. I'll think about shipping after the show, but shipping will probably kill any deals. Thanks. Jim
#18 |
They said the heads would be set up for unleaded gas, so I think that meant hardened seats. Jim
#19 |
How long has it been removed from the truck?
#20 |
What about the exhaust headers?
Thanks Posted via Mobile Device |
#21 |
Jim, understood and I know shipping can be a pain on large items.
But recently I shipped a motor to Oklahoma from NJ and it was only around $300. Scott
#22 |
if shipping is 300 or under im proble game
#23 |
or maybe meet up?
#24 |
Sorry guys. Right now I'm not looking to ship or travel. I'm working on building a stand to run on. Have it bolted up at tranny mount and building motor stands today. Then hook everything up and run. I will be taking to Pettie Jean car show in my truck bed first. If can't sell local or pickup, will check on shipping. The stand is built to be forkable. Thanks again, and sorry. Jim
#25 |
Sorry, just found out Petit Jean show doesn't start till Wednesday. Setup is on Tuesday I guess. Thanks. Jim
