Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-02-2011, 05:20 PM   #1
pockets
pockets's Avatar
2 piece DS and loop
I've read in the NHRA rule book that you have to have a loop for any vehicle 13.99 or quicker and/or slicks. So, my question is with a two piece is there any specific rule? Like needing a reinforced carrier bearing or two loops or anything else?
Project Bad Karma
pockets is offline   Reply With Quote
Old 06-04-2011, 02:28 AM   #2
bigjimzlll
bigjimzlll's Avatar
Re: 2 piece DS and loop
I run a 2 piece on my 9 second truck. 850+ horse power. TH400, 4.56 gears, 32.5x14 slicks. It is a custom made driveline. The NHRA rule book only states you need a DS loop 6" from the front U joint. This is so if the front joint fails you don't pogo over it. I installed one a the tranny then another DS loop after the carrier bearing.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 06-04-2011, 05:13 PM   #3
pockets
pockets's Avatar
Thanks!
Project Bad Karma
Old 06-04-2011, 07:13 PM   #4
blackedoutharley
Another consideration for the loops is to also keep the shaft from coming into the car... not a big deal on a pickup compared to a car but it can and does happen.
blackedoutharley is offline   Reply With Quote
