light switch help
okay guys were is the ground wire for the light swith its self ,or is it self grounding
Senior Enthusiast
Re: light switch help
I believe it is self grounding through the dash attachment. There should also be a grounding tab on the light switch frame, but this is for operating the dome light. The dome light receives constant power direct to the bulb, and operation is controlled by the ground.
To eliminate grounding problems in the dash, I ran a separate ground wire from the engine block where the negative battery cable connects, to the pedal support. All gauge grounds connect to the pedal support, and this also provides a positive ground for the dash itself. It's an easy way to avoid those hard to diagnose electrical gremlins. Last edited by markeb01; 06-03-2011 at 01:17 AM. |
Thanks for the help im working on a 1968 that may have helped.I got the truck yesterday its been butchered all the wiring is messed up bad the alt wire was melted and the tail lights went even hooked up,i got the tail lights to work with a test wire from the battery. The truck keeps blowing fuses at the battery when the alt is hooked up i can start the truck when all the alt wires are off. Any ideas, thanks again for the help its needed
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Dude, if you can afford it, replace that harness, you will have nothing but problems in the future if you dont, I sure did.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Who Me?
I dont have a ground on mine. Its just a constant hot to the switch and the different outputs from there. It will work wether its mounted or not.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
