DJM Flip kit #FK1024-5 ??
I just got my DJM Flip kit from ups today, First thing i did was take the U shaped (axle locater?) And stick it under my stock spring perches. I have a stock 10 Bolt, 85 C10.. The center of the U shaped piece hits the axle before the sides of it hit the bottom of the spring perch. Is this a problem? Im not sure if this is how its supposed to be so you can set the pinion angle...?
Im putting it on Saturday night and just want to be sure before i get everything torn down and realize, OH S**T this doesnt fit. As far as i know its a stock 10 bolt w/ 3:08 gears. Its the 85 Dollar one on summit, FK1024-5. Let me know if you need more info.
85 C10 LWB 305ci - 700r4 - 10 bolt - 3:08 gears Collecting parts for a 'mild prerunner" ![]() |
Happy to be here
![]() Join Date: Mar 2000
Re: DJM Flip kit #FK1024-5 ??
I looked it up so we could have a visual. The saddle should fit up against the spring perch. How close is it to making contact on the sides?
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 06-03-2011 at 10:54 AM. |
.25 inch on each side. what does this mean?
DURRRR! i must be an idiot, It has about 1/16 on each side when its in the middle of the axle, and it fits when its pulled slightly back into the purch. Didnt even realize that the whole idea of a flip kit was to slightly move the axle back. DOH!
Well better safe then sorry right!?
Happy to be here
No worries! Give us a before and after pic when you get it done.
well its comin from a 3/0 lift. So ill post it up
Update?
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
