06-03-2011, 10:31 AM | #1 |
Removing frozen bolts in bed
Looking for some ideas to remove the bolts in my truck bed. I have soaked with PB blaster, but the bolts spin when I try to remove the nuts. Any way of keeping the bolts from spinning or should I try nut splitters etc. Don't really want to grind the bolt heads and damage the truck bed.
Thanks for any suggestions. |
06-03-2011, 10:35 AM | #2 |
Re: Removing frozen bolts in bed
Not sure if you have a welder but welding a hex nut to the top of the bolt works well.
06-03-2011, 10:46 AM | #3 |
Loose... good idea..
06-03-2011, 10:55 AM | #4 |
And on the rest of em just tighten and break off trust me its quicker ..
06-03-2011, 10:57 AM | #5 |
sawzall was the only way i could manage
06-03-2011, 10:59 AM | #6 |
Moderator
Best way to do it. Overtighten and snap them off. You will be done in minutes as opposed to hours.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
06-03-2011, 12:18 PM | #7 |
i take my small cutoff wheel and grind the tops off
06-03-2011, 05:41 PM | #8 |
The easiest way I found to remove frozen bed bolts are with a 4" or 3" cutting wheel.
I crawl underneath and cut vertically through the nut and bolt. Sometimes you only have to cut halfway through and the nut will come off with a wrench or socket. This prevents you from messing up your bed. If you're good at cutting, you can cut through the nut it will split off the bolt.
'69 Fleet It ain't yours, if you didn't build it! Last edited by Dano69c10; 06-03-2011 at 05:41 PM. |
06-03-2011, 06:10 PM | #9 |
Roadtrip!
The only way to go. Its not like you are going to reuse the bolts anyhow...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
06-04-2011, 12:12 AM | #10 |
x2
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
06-04-2011, 01:25 AM | #11 |
SLOW POKE
I had to use a catspaw & a sawzall
68 SHORT-BED-STEP-SIDE piece by piece ,
day by day , I will restore this truck , before the 100th anniversary !!! |
06-04-2011, 10:21 AM | #12 |
Thanks for the posts. Awesome ideas. If I can get the truck to my buddy's, I'll weld. If not, I'll cut. Thanks again. This was a ton of help.
06-04-2011, 10:29 AM | #13 |
Yeah, and the fact that they're frozen makes your bed cold as well!
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
06-04-2011, 05:59 PM | #14 |
454 MAKES IT ROAR
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
06-06-2011, 09:48 AM | #15 | |
BTW, I couldn't get to the welder, so I cut like you suggested and it worked beautifully. Only took a few hours and the box was off. Thanks for the tip. |
