Old 06-03-2011, 12:01 PM   #1
jwa76fleetside
jwa76fleetside's Avatar
wont start
its acting like its not getting gas.....if i spray starter fluid in the carb it will fire but then promptly die......can you start me in a couple directions to fix? is it a fuel pump?
76 Chevy Fleetside
63 Lincoln Continental w/ Ford Racing 460 (550hp)
2012 VW GTI
2013 Escalade
2008 Harley
jwa76fleetside is offline   Reply With Quote
Old 06-03-2011, 12:14 PM   #2
Togart
Togart's Avatar
Re: wont start
Need more info....has it been run recently and this is a new problem, or has it been sitting? What kind of carb is it? Could be fuel pump, easiest way to check that is to disconnect the fuel line at the carb...if you get fuel coming out there then your pump could be ok. If you pump the gas pedal and you don't hear it squirting in the carb, then could be a plugged fuel filter, a stuck float in your carb, or a bad accelerator pump. If you aren't getting fuel to the carb, could be pump, or clogged sock at the tank end of the line.
Togart
'66 GMC 1500
'77 C-10 Scottsdale Big 10
Togart is offline   Reply With Quote
Old 06-03-2011, 12:27 PM   #3
rjn72
rjn72's Avatar
Re: wont start
Very possibly the fuel filter in the front of the carburetor.
JESUS IS LORD
87 crew cab V30 454/400
rjn72 is offline   Reply With Quote
Old 06-03-2011, 01:55 PM   #4
PRattenbury
Re: wont start
If it's a 76 truck and it's stock then as mentioned above disconnect the fuel line from the carb, stick it into a 2 litre bottle. Turn the engine over and see if the pump is putting out any gas. (After making sure there is gas in the tank, of course).
PRattenbury is offline   Reply With Quote
Old 06-03-2011, 06:19 PM   #5
jwa76fleetside
Re: wont start
only problem is it wont run for more than a second when i try to start it? how will i see if its putting gas out of the fuel line if i can get it to run? should i just keep trying to crank it over?
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
Old 06-03-2011, 06:32 PM   #6
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Re: wont start
If you put a clear fuel filter on it, it will help you diagnose if fuel is getting to the carb. Like was mentioned earlier, take your fuel line from the tank off your pump. Put that fuel line into a small 1 gallon gas can or something that will hold a little fuel (so the fuel line is still on the pump, just not coming from the tank anymore). Turn the engine over in your truck (either from inside or by jumping the starter, it doesn't matter). You'll see if fuel is getting to the carb with the clear filter. If it's not, then your pump is bad. If it is, then there's something wrong with the fuel lines coming from your tank.
If fuel IS getting to the carb, then take the hard line off that feeds the carb and clean out the mesh filter that's in there. See if that helps any.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 06-07-2011, 11:28 AM   #7
jwa76fleetside
Re: wont start
thanks i will give this a try!
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
