Foom, foom, foom!
![]() Join Date: Mar 2005
Looking at replacing my stock camshaft for a Hydraulic camshaft.
Do yall have any recommendations? Brands? Part numbers? The engine si a stock 350 4 bolt main, and I'm not quite ready to stroke it to 383. Just looking for something that will drive good day to day and will give me some extra power. thanks
- Dan 84' LWB C10 // 2.5" from collector back. duel Turbo Mufflers // 350 w/ TH350 long Headers//3.73 rearend gears Future Mods 3/4 suspension drop ![]() |
#2 | |
Re: 350 Hydraulic Camshafts
It's a 99.9% bet that the cam in there now is "hydraulic"....what is the issue you are having? why replace it?
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
your cam now is a flat tappet hydraulic cam. If the rest of the motor is stock. leave the cam stock. If you do heads, intake, carb, etc.... THEN i would consider it. I would look at comp cams 268h.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
#4 | |
For a step above stock flat tappet hydraulic cam on a basically stock engine (while keeping emission compliance ) the following cams provide additional performance without degrading idle quality or fuel consumption. These are commonly referred to as RV cam. Part# CS1014R MFG: Speed Pro RPM range:1500-4000 Converter: Stock Int/Ex Lift: .420/.443 Adv Duration: 278°/288° Int/Exh Duration @0.050: 204°/214° LSA: 112° Part# 266H Mfg: Crane RPM range: 1500-4000 Converter Stock Int/Exh Lift: .440/ .440 Adv Duration 266/266 Int/Exh Duration @0.050: 210/210 LSA: 110 Part# MTC1 MFG: Melling RPM range: 1500-4500 Converter: Stock Int/Exh Lift 0.420/0.443. Adv Duration 278/288 Int/Exh Duration @0.050 204/214 LSA: 112 Part # SUM-1102 MFG: Summit (probably Melling or Elgin) RPM range: 1,500-4,000 Converter: Stock Int/Exh Lift: 0.420/0.442 Adv Duration: 262/272 Int/Exh Duration @0.050 204/214 LSA 112
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
#5 | |
EDIT: look for "normal-mild" idle.. NOT "ROUGH" Last edited by cr34t3d_by_d4rkd3n; 06-05-2011 at 06:14 AM. |
Foom, foom, foom!
Longhair, I wasn't really having problems with it. Recently blew a head gasket; and I figured since I was going have to rebuild the whole to topside the engine; I'd might as well go for an upgrade. I'm also replacing my quadrajet with a Edelbrock 600 CFM/a performer intake.
Wow, thanks all for the great info. Yes, an RV cam is what I am really looking for.
The more "duration" you have the more the power band goes up in the RPM range. Not good on a heavy vehicle. If you have a big lopey cam it will be a dog until the RPMs get way up there.
#8 | |
Yes the RV cam is the way to go for street use. Every time I went for a so called mild cam the car rocks from side to side at idle, no vacuum for power brakes, needed a stall converter, lower gears, a huge trans cooler, a ton of fuel and slicks. So much for the mild cam theory. Ah but what a ride lol |
![]() Join Date: Jan 2003
1969 ![]() 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
