06-03-2011, 08:27 PM | #1 |
What tools are in your truck at all times?
1 month and 1 week with my "new" 72. I can tell it's going to be a little temperamental. I put a couple of canvas zipper bags in my truck with an assortment of combo wrenches, 3/8 sockets, ball peen hammer, adjustable and needle-nose pliers, and a few screw drivers. Stock jack and handle and after market lug wrench. I was just wondering what ya'll keep for road side breakdowns, slow downs, hoe downs, etc.
1972 C-10 Deluxe 350 V8 - 350TH ------------------------------ We're not the jet set We're the old Chevrolet set |
06-03-2011, 09:09 PM | #2 |
its all about the +6 inches
Re: What tools are in your truck at all times?
I'm the only tool in my truck all the time.
06-03-2011, 09:11 PM | #3 |
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
06-03-2011, 09:15 PM | #4 |
06-03-2011, 09:16 PM | #5 |
I've been meaning to put together a tool kit for each of my vehicles for a while now, still haven't gotten around to it.
cheap test light spark tester tire plugs bicycle tire pump spare ignition module / points for distributor fire extinguisher flash light If I keep going I should just get a tow bar and attach it to the front of the local Snap-on truck |
06-03-2011, 09:54 PM | #6 |
Grandpa in the rustmobile...
i think i have a 9/16 1/2 a screwdriver or 2 maybe a bungee cord and some cutters/pliers...
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
06-03-2011, 10:03 PM | #7 |
I have a lug wrench, but I don't have a spare or a jack.
So far, I haven't driven my new '68 further than I'm willing to walk home from. I suppose I'll get a tool kit together for her first workout-I have a couple tons (I hope) of scrap iron I'm gonna haul down to the big city next week. I have my truck-bed trailer loaded already, and I'll load up 'ol green closer to show time.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
06-03-2011, 10:08 PM | #8 |
20' Daredevil (Ret)
I recently got a 6T bottle jack to replace the old 3T jack. The 4-way is always behind the seat. That's it, unless you count a 30' cable and a couple log chains.
06-03-2011, 10:23 PM | #9 |
I am a Referee of life.
I usually carry a blow molded tool kit if I'm going out of town.Other than that,a pair of channel locks,a 9/16ths and small cresent are in the glovebox.I have only needed any of it once since I tend to use my vehicles to only about 40-50% of their reliability.The one time I needed something,it was a terminal end and by luck I had one in my pocket from a work related repair earlier in the day.The channel locks loosened the nut and crimped the power wire to the coil.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-03-2011, 10:41 PM | #10 |
i take my tools with me in my dd a 99 ferd f250 superduty and when i go on roadtrips more that 20 miles with my chevy. it got craftsmans full screwdriver set, 1/4 3/8 ad 1/2 in drive craftsman and s&k ratchets a buttload of 3/8 sockets and 2 rails of 1/4 and 1/2 inch sockets along with many extensions and pliers, tape measure, teflon tape, valve stem tool, ect.
1972 longbed- 454 1967 shortbed- 355 |
06-03-2011, 10:44 PM | #11 |
I have a little blow molded tool kit that has a bunch of sockets in it, 4 sizes of wrenches, a screwdriver with a bunch of tips, then I throw in a pair of pliers, and a set of jumper cables.
The test light is a darn good idea. |
06-04-2011, 12:34 AM | #12 |
Two quarters to make a call and a pint of Jack whaile you wait for the roll back.
1969 C-10 short step 1981 CJ7 2017 Ram 2500 Laramie 4X4 1939 Cadillac LaSalle sedan 1950 Allis Chalmers B 1998 Bullet 21 XD 300 Merc/water hot rod |
06-04-2011, 12:42 AM | #13 |
In my '68, witch only really goes to shows, is a LED light flashlight, adjustable pliers, needle nose pliers, and fuses.
In my dd '95 Chevy I have in my tool box, full assortment of wrenches and sockets, full construction tool pouch (hammer, screwdriver, ex.), 3/8" log chain, 1/2" log chain (just in case ), 50,000lb tow strap, 4 treated wood 4x4's, bungee cords, ratchet straps, extra oil, antifreeze, brake fluid, trans fluid, rags, funnel, and some other things that I don't use on a daily basis. If something happens to the '68 then the '95 is not very far away to come and save it .
'68 Chevy C-10 50th '69 Chevy K-20 Long Stepper '95 Chevy K1500 |
06-04-2011, 01:13 AM | #14 |
My Carbon Footprint
S&W P99 in .40 cal. It's kind of like a cordless drill.....Will make bit holes really quick (10 of them to be exact) and the bit never dulls.
06-04-2011, 01:32 AM | #15 |
>>I have a lug wrench, but I don't have a spare or a jack.<<
Same here, but if I'm lucky I'll try to remember the cell if I'm going out of the area. Discovered the water pump was bad a couple of weeks ago. I was about ten miles out and the temp started going up when it was almost out of water. Put water in and drove home. It never did OVER-heat. About twenty years ago I snapped the crank in half between the 4 & 5 journal. Drove the fifteen miles home. Threw a new crank into the bottom and drove another ten years. With a straight six you don't need no stinking tools to get home. HA HA
'67 GMC 2500, 292, 4spd, AC |
06-04-2011, 09:12 AM | #16 |
Vice grips, multi-bit screwdriver, dogbone multi-socket
06-04-2011, 12:17 PM | #17 |
Between Trucks...
Socket set. screw driver set, crescent wrench, jumper cables, 12 volt impact wrench, extra belts, bottle jack and spare tire, fix a flat, and a milk crate with various oil, trans fluid etc. Need to pick up one of those 12 volt jump start things and some spare radiator hoses.
Beat it to fit, Paint it to match... |
06-04-2011, 12:19 PM | #18 |
Nothing, it's a Chevy
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
06-04-2011, 12:27 PM | #19 |
AAA Premier card,
along with pliers, two screw drivers, HEI module, spare drive belt. And yes it's been flat bedded home more that once in the 15 years I've had it.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
06-04-2011, 01:19 PM | #20 |
vice grips for rolling my window down :P
06-04-2011, 01:30 PM | #21 |
I always have my tool box under the seat of my truck.I use an old ammo box that i got from a friend.
I have it stuffed with all kinds of tools.Mini wire brush(very handy for old trucks),wire strippers/crimper,needle nose,vise grips,e-tape,5/16 nut driver(beats stabbing your hand with a flat screw driver on hose clamps),ratchets,sockets(deep and short),Extensions,lots of wrenches including line wrenches.A BFH too.The lid to the box has a rubber seal to keep moisture away from the bullets.I threw the box with my tools in it in the lake and left it there for a week.When I took it out and opened the box,my tools were bone dry
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way) 72 Custom Deluxe Burb(Arizona truck)Nice interior Great patina Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668 Last edited by Flint70step; 06-04-2011 at 03:08 PM. |
06-04-2011, 04:45 PM | #22 |
The only tool I have in my truck is my cell phone.
Posted via Mobile Device |
06-04-2011, 04:47 PM | #23 |
Old Skool Club
I never go anywhere without my fire extinguisher. Saved my truck, once.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
06-04-2011, 04:57 PM | #24 |
well when mine is on the road i will have a jack lug wrench and 1/2 inch 9/16, 5/8, 7/16ths and flat head and phillips head screw driver thats all we need
06-04-2011, 06:49 PM | #25 |
x2 on none its a Chevy
04 GMC CCSB SLT Duramax 78 Chevy 3500 454 68 Chevy C-10 98 Arctic Cat 1050cc 9.66/135 1/4 mile asphalt |
