Old 06-03-2011, 09:29 PM   #1
rhd_c10
rhd_c10's Avatar
help with tranny crossmeber clutch swap
I just got my 68 swb with a 4 speed straight 6...clutch when out so I need to drop the trans..not ready for the 5.3 swap yet......
My question is how do I drop my trans with out pulling the motor . it looks like the crossmember is riveted in..
rhd_c10 is offline   Reply With Quote
Old 06-04-2011, 01:28 AM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: help with tranny crossmeber clutch swap
Moving you for some more help...
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 06-04-2011, 09:46 AM   #3
68gmsee
Active Member
68gmsee's Avatar
In my 68 GMC with 250 six and 3 speed saginaw I didn't have to mess with the crossmember. I have plenty of room to remove the transmission behind the engine.
forgot to add: I'll post a pic of mine from underneath for comparison.
68gmsee is offline   Reply With Quote
Old 06-04-2011, 10:03 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Here's the pic of mine. Unbolt it all the way around including the engine mounts and slide it backwards.
IIRC the problem I encountered was the parking brake cable. It may be better if you remove it so it's not in the way. Also, use a small hydraulic jack and block of wood to hold the engine up and/or lowering it if you need to.
As you can see I just had to replace rear trans seal and speedometer bullet o ring for leaking...lol
Old 06-04-2011, 10:38 AM   #5
javadoc
Hey Watch this...
javadoc's Avatar
You can also drill out the rivets if you find that you need to remove that cross member. That's what I did, and just bolt it back in place.
What have I gotten myself into now?
1964 Chevy Stepside - 383 hydraulic roller Vortec ... a work in progress
2000 Volvo V70R - 340awhp, 22psi, meth-injected of Porsche-eating fun. The grocery-getter on steroids
javadoc is offline   Reply With Quote
Old 06-04-2011, 03:35 PM   #6
rhd_c10
rhd_c10's Avatar
Thanks for the help
Old 06-04-2011, 07:10 PM   #7
blackedoutharley
I assume that you're referring to the 4 speed granny gear transmission... which weighs a TON!
If possible just unbolt it from the bellhousing and move it back enough for the input shaft to clear the clutch.
Depending on the size clutch you should be able to remove and replace it from the bottom of the bellhousing.
blackedoutharley is offline   Reply With Quote
