Transmission crossmember interchangibility
What year transmission crossmembers are interchangable? I threw my old one from my 82' out because of the PO's hack job and picked up one from 87' dually burb (off of his 90' Burb).
Tried to put in in tonight and it's not even close to fitting. Any ideas??? Am I going to have to drill some new holes to install the one I got from Chris or get one from another 81'-82'? Can not put the motor and Muncie in with out one. I knew I should have kept that old crossmember!!!!!!!!!!!!!!!!!!! Here is a pic of where the part that mounts to the underside of the top of the frame is mounted. Is this the correct position for a TH350 or a Saginaw 3 spd? What I pulled out of there was a Olds TH200 and the PO had to notch the crossmember for the tranny pan to clear.
The Fleet........ 68' Camaro - 1st car (restored & still have it) 09' VW Tiguan (Wife's Daily Driver) 14' VW Passat SE TSI (my personal) 14' Ford Edge Sport (Daily Work Vehicle) 73' SWB Stepside - 77K org. miles 74' LWB 454/TH400 - drive train transplant for my (Sold) 98' SWB C1500 W/T - shop truck (Sold) 90' GMC Sierra SLE short step - aka " Jezabelle " (Sold) |
Re: Transmission crossmember interchangibility
Anybody?? I know someone has the answer. I am gathering there wad s cross member Change in the mid 80's. One of you guys chime in who have done the auto the manual swap. Anybody made their own cross member or modified one?
I didn't know there was a x-member change, but would think that any 2wd would work or be close enough to modify??
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
At the body shop.
Early ones without a cat leave the most room for dual exhuast. Im using one from a 3/4 ton. It requires some fab work for a 1/2 ton though.
" That didnt make it any newer " " Dont antique the equipment " |
This what my 76 blazer has. I pulled an identical one out of a 80 3/4 with a turbo 350/205. Did the crossmembers change when they went to aluminum transfer cases?
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
At the body shop.
ECU 2wd or 4wd
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 06-04-2011 at 09:21 PM. |
my bad, I think he is looking for 2 wheel stuff
![]() Join Date: Dec 2010
Just dump the ugly factory crossmember & build your own (or have it built) like on my truck. It'll be better all the way around!
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
Here is where we are at this morning
Another shot. The holes to mount it to the bottom of the frame are about 1" shy of making it........ I guess I will be going to the pick and pull because this 90' Burb cross member will not work
Here are some shots of the one I took out. Looks the same but, I just can't figure out the problem
Maybe I just foound my answer or at least as couple of different directions to take.......
http://67-72chevytrucks.com/vboard/s...d.php?t=307481
#13 |
Finally wrestled it in last night. Still need to do one bolt on the bottom of the driver's side of the frame and the two on the bottom of the passenger side. had to break out the 2 ton floor jack to make it happen. Might need to break out the 5 pound hammer to get it snug............
