06-04-2011, 01:05 AM | #1 |
Crooked Steering Wheel Now Straight???
Hi Guys,
When I bought my truck I noticed that the steering wheel was not straight when the wheels were centered (pointing forward). I'm not sure if I'm imagining this, but it seems to be straighter now than it was. It's got me worried that something is slipping within the steering box or steering linkage?? Anyone ever had this problem? I want to make sure it's safe to drive. |
06-04-2011, 01:14 AM | #2 |
My Carbon Footprint
Re: Crooked Steering Wheel Now Straight???
Did you happen to move your head upright? lol
Sorry....just trying to be funny! |
06-04-2011, 05:34 AM | #3 |
Check the mounting bolts on the steering box.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
06-04-2011, 10:29 AM | #4 |
Active Member
I'd have a front end alignment done just to make sure. Also check the air on the front tires to make sure they're the same.
Another thing may be tire wear. Could be possible you have a tire that has a slipped belt and it may be pulling slightly to one side. Maybe swap with rear tires to see if it goes back to the way it was. If all of that checks out... You're in luck! Got a self healing truck. |
06-04-2011, 12:56 PM | #5 |
Thank you for the replies! I'll check the mounting bolts and the tires and alignment. I don't want to worry about nothing but I want to be safe.
Thanks again. |
