Old 06-04-2011, 11:01 AM   #1
82Cecil
82Cecil's Avatar
floor shifter connection to transmission?
6.0 swap using 700r4 tranny 82 C10 shortbed
Attached pic shows column shift linkage hitting O2 sensor position on driver side header.
Would a floor shifter solve this or does it use the same set up, only relocating the shifter location in the cab?
Can this problem be solved by switching to a floor shifter.
82Cecil is offline   Reply With Quote
Old 06-04-2011, 11:33 AM   #2
fanmanj
fanmanj's Avatar
Re: floor shifter connection to transmission?
Personally I think it would be a lot easier to just move the O2 sensor...
Jay Bernard, Thibodaux, LA
1986 SWB Sierra Classic
Stock roller 350/700R4
2008 Buick Enclave CXL
3.6 VVT, 6spd auto.
PAINFULLY stock... (wife's ride)
fanmanj is offline   Reply With Quote
Old 06-04-2011, 12:01 PM   #3
ghettoluxury
ghettoluxury's Avatar
Do you self a favor and have the O2 bung moved. I just had to do this on mine to clear the frame.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 06-04-2011, 12:08 PM   #4
82Cecil
82Cecil's Avatar
This my attempt at 1 3/4" primary long tube headers.
I eventually plan to go to a floor shifter later, but will do it sooner if it provides a solution to this problem. If switching to a floor shift does not change the use of the horizontal bracket/rod, then moving the bung sounds like the way to go.
These are Schoenfeld 1302 LS 1 headers intended for the 88 thru 98 1500s
the driver side slips in so nicely from below, and the passenger side needs a little work on the no. 2 cyl exhaust tube.
Thanks for the reply
Old 06-04-2011, 02:32 PM   #5
Pop's C-10
Pop's C-10's Avatar
If you add a floor shifter,that what's geting in tha way is not needed. You can jus remove it.
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 06-04-2011, 03:00 PM   #6
82Cecil
82Cecil's Avatar
thanks for the info.
I wasn't sure how the floor shifter works or connects because I have never had one.
Old 06-06-2011, 02:22 PM   #7
Pyrotechnic
Pyrotechnic's Avatar
My B&M Megashifter uses a cable which you can route how you want.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 06-06-2011, 08:34 PM   #8
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Just remember, you don't want your O2 at 6 o'clock or "straight down" as moisture will collect on and in it and it'll go bad quickly.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 06-07-2011, 09:50 PM   #9
82Cecil
82Cecil's Avatar
I think I'm going to check out a B & M truck Mega shifter
Old 06-08-2011, 12:40 AM   #10
hotrod_991
hotrod_991's Avatar
agree with the floor shifter I have a b&m also and with the cable wont even be close to the sensor or that side of the header collector.
"Buckle up I wanna try somethin!!"
"of course it will hold!, I welded it!"
1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint
hotrod_991 is offline   Reply With Quote
