Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 06-04-2011, 04:03 PM   #1
dlatulip
Cleaning out sale
Keep looking on the 1st post. I will update/add/remove daily.
All prices DO NOT include shipping! But all prices are negotiable
Edelbrock Remote reservoir shocks. New at Jegs $182 each.
Medium Valving Part# 63901 Extended 23.35" Collapsed 14.45" Stroke 8.90" Remote Mount holes HS13/HS13 Zinc finish
I have 4 of these new in the box. 2 boxes opened. All 4 for $540, 2 for $280
Name: Shock.jpg Views: 134 Size: 4.8 KB
Stock front tow hooks Chev $30 (2nd Gen)
Wiper Motor Pulled from the 90 only used 2 Months $20
Dana 60 F Open Carrier $50
Corp 10 carrier $10
14SF 4:10 Ring and Pinion $50
AC compressor. (Newer model) Make a offer
700R4 to 241 adapter Will also work on a 208 to TH350 $45
Transmission Hard lines 700R4 90 Blazer. $40
Green door panels Plastic 1972 $25
Door Hinge New 73- 87 LH top $8
Like new front drive shaft 25 1/4 compressed 28 1/4 Extended. Was mounted on a 72 blazer 205/D44 $75
Used starter from 90 K5 $10
Corp 10 bolt rotors/hubs/calipers almost new pads $25
New shock boots. I have 4 black and 2 red. $3 each
3" Stainless Exhaust tip fits on 2 1/2" tailpipes Edelbrock 5582 New is $45 I have 2 $60 for the pair.
New unk brand shocks 17 1/2" compressed 29 1/2 extended $20 pair
2 piece fan shroud pulled from the 90 blazer $30
Lincoln Mig weldpak 100 converted to gas already with gauges. Works great. $250
Fan blade and clutch 5 Bladed pulled from 90 Blazer $10
Rear seatbelts 90 Blazer Lt Grey/Blue $25
Blazer Bucket seats from a 90 Blazer Lt Grey/Blue $75
Receiver hitch pulled from the 90 $50
Clutch pedal parts from a 72 Blazer $30
Single Hub M/M all steel $5
New coil Napa IC29 GM 90 Blazer and many others $20
New MSD Master Blaster 2 Coil Tower type. $30
32 9/16 Lug nuts tuner 6 spline style with Key New $25
Power Tank Monster Deflators New MON 8200 $90
Battery trays, Dual, Driver and Pass. Pulled from the 90 Blazer, in great shape. Both $50
K5 Blazer fender Badge 1972 $15
Blue Center console 90 Blazer (two small cracks by the hinge)$35
Interior Spare tire mount with cover 90 Blazer $25
dlatulip is offline   Reply With Quote
Old 06-04-2011, 05:37 PM   #2
akbates21
Re: Cleaning out sale
interested in the hitch and the a/c compressor. Is the A/C for a big block or small block? How about pictures of both.
akbates21 is offline   Reply With Quote
Old 06-04-2011, 06:07 PM   #3
dlatulip
No pics until Monday night and the Compressor came of a 96 Vortec motor with a Serpentine setup. Says Delphi 4344. It's an R4 style compressor. Many applications. Looks like this one. I will post some actual pics on Monday.
Old 06-04-2011, 09:51 PM   #4
thinair
thinair
thinair's Avatar
Dual stabilizer.........end to end or stacked?
thinair is offline   Reply With Quote
Old 06-04-2011, 10:35 PM   #5
madcow75
madcow75's Avatar
factory dual shock mounts please. Can I have a pictures. Please.
madcow75 is offline   Reply With Quote
Old 06-05-2011, 04:09 AM   #6
dlatulip
End to End!
Old 06-05-2011, 10:43 AM   #7
thinair
thinair
thinair's Avatar
Got a pic? And shipping quote to 68128
Old 06-05-2011, 05:27 PM   #8
akbates21
I am out on the a/c compressor but still interested in the hitch pending pics
Old 06-05-2011, 05:36 PM   #9
dlatulip
Originally Posted by madcow75 View Post
factory dual shock mounts please. Can i have a pictures. Please.
Old 06-05-2011, 05:40 PM   #10
dlatulip
I will ship it for $16.
Old 06-05-2011, 06:11 PM   #11
dlatulip
Without knowing your exact zip or if it's going to a home a business it's hard to quote. I think it's going to be at least $35 It weighs 33 pounds. Business address will be cheaper.
Old 06-06-2011, 07:43 PM   #12
csa daddy
csa daddy's Avatar
how much for the shackle flip shipped to 24550
csa daddy is offline   Reply With Quote
Old 06-06-2011, 09:35 PM   #13
akbates21
thanks for the pic of the hitch i was needing the longer one so Im gonna pass. Thanks
Old 06-06-2011, 10:26 PM   #14
dlatulip
Sold today.
Old 06-07-2011, 11:15 AM   #15
thinair
thinair
thinair's Avatar
You have the other bracket that mounts to the tie rod also................correct?
Old 06-07-2011, 12:28 PM   #16
dlatulip
The single stabilizer mounted in the stock location. Since I had a 90 blazer I will see if I can find a pic. I guess you could also use the main bracket to the tie rod with few bolts. I will see if I have another bracket in case you don't won't to mount it the way I had it.
Old 06-07-2011, 09:33 PM   #17
dlatulip
Here is how I mounted them. I also did find the other bracket.
Old 06-08-2011, 01:31 AM   #18
thinair
thinair
thinair's Avatar
PM me your payment info for the dual stabilizer setup. Matt
Old 06-09-2011, 02:56 AM   #19
thinair
thinair
thinair's Avatar
you have money!!
Old 06-09-2011, 05:38 PM   #20
madcow75
madcow75's Avatar
Money sent for dual shock mounts and zero rates. Okay?
Old 06-10-2011, 05:03 PM   #21
RFOX
RFOX's Avatar
Got any pics of the fan shroud?
1997 CHEVY K3500 DUALLY 454 (SOLD)
1982 GMC JIMMY 2WD 350 (SOLD)
1994 TOYOTA 4X4 4 BANGER (SOLD)
1985 SILVERADO 2WD 400sb(SOLD)
1993 CREW DUALLY 500 CADILLAC (SOLD)
1989 C1500 GMC SEIRRA 350
RFOX is offline   Reply With Quote
Old 06-11-2011, 09:41 AM   #22
dlatulip
Just a little dirty. No cracks or pieces missing
Old 06-12-2011, 06:56 AM   #23
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
Any idea on what class that hitch is?
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
