Dana 44 axle
I was changing out my ball joints on my 72 Blazer and I took the rotor off. The axle came out a bit so I figure I would just take it out completely.
My question is, is there anything supposed to be holding the axle into the center section or do I just put it back in. Does it not have a C clip like on a rear diff?
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
Re: Dana 44 axle
NO "C" clips holding in the front axle shafts.
1978 K-15, 350/350, 4.11's, 17" KMC's, 37's. ![]() |
Re: Dana 44 axle
Thanks, I just put it back in and havent heard any grinding from the axle yet so I guess I put it in right.
God is good!
Re: Dana 44 axle
Check out my build for a complete how-to on this if you'd like. Got a lot of pictures in there. I'd really encourage you to replace the inner axle seals and axle u-joints, too.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 Last edited by TheWhiteElephant; 06-06-2011 at 09:38 PM. |
Re: Dana 44 axle
Well after seeing the pictures on your rebuild I think I will replace the axle seals and u joints since you make it look so easy. My u-joints seem ok but one of my axle tubes is always wet.
God is good!
Re: Dana 44 axle
Good thing you caught that. That's definitely a sign of a bad seal. Mine was exactly the same way. If you need any help, feel free to shoot me a message.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 Last edited by TheWhiteElephant; 06-08-2011 at 12:03 AM. |
Getcha Pull
Re: Dana 44 axle
That is simply GM's built in oiling system. Mine is broke, my axle shafts are a little rusty.
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
