fat old dude
![]() Join Date: Feb 2010
current workhorse issues
hi need some help with an issue on my 94 astro van. didnt know where i could post it. its basically got a truck frame and drivetrain right. well heres the deal. the door hangs a little and it makes it hard to pull it open so ive broken the handle a couple times. ive gotten another replacement but id like to make it stop hanging, im getting tired of jumping the seats to open it. someone told me i can replace the bushings on the door? i dont even know how to pop the door off. i tried to on a junkyard one and it was a FAIL. thanks, im including some pictures.
Door closed ![]() door hanging. u can see it better on top part. ![]() inside door, bushings and removal are here?? ![]()
1972 c-10 shortbed 350/400 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157 1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216 Accepting part donations |
fat old dude
Re: current workhorse issues
Should i have put this somewhere else
just knock out the hinge pins and put new bushings in. possible new pins and bushings would be the way to go. these doors are like the s10's no adjustment at the hinge. use a jack and a friend to hold the door so you dont drop it.
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done... |
fat old dude
Pop em with a hammer? Or hit the bottom part with a chisel and hammer
ypu just knock out with a hammer, just dont beat then up to mich tho. s store most of them have new pins and bushing on one of there racks. pending on your hinges you mite have to drill the holes just a tad for the new bushings as the holes could be out around abit.
store, meaning your local auto parts place
oh yea the bottom pin you hit up and the top one down
#16876
Yep just pop out the pins and replace the bushings with new ones from a retailer not wrecking yard. They are designed to take the wear so the hinges do not.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
![]() Join Date: Nov 2004
I replaced the ones on the DS door of my S10 this past summer. The hinges were fine but the bushings were shot. That spring is a pain in the butt, but there's a special tool that makes taking it out and putting it back in much easier. I think mine was about $5.
What everyone else has suggested is what I did. Used a jack/wood block to hold door, removed spring and pins (also disconnect any wires BEFORE doing this, nothing worse than getting the door loose and ripping the wires out!) then pulled the door off, set it to the side, removed old bushing, installed new ones, put door back on, then the new pins, then the little spring and my door open and shut normally again.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
fat old dude
thans everyone, i'll be tackling it soon. i chcked the autozone site and the bushings are $6. pretty cheap
