06-05-2011, 05:48 PM | #1 |
window regulator?
Passanger side on my 69 c10 is alittle sticky.Never have fooled with a regulator before,any suggestions other than pay attention to how everything is assembled?Is the regulator itself the most common culpurit?Thanks.
06-05-2011, 08:11 PM | #2 |
Restoration Virgin!
Re: window regulator?
probably being 40+ years old, needs a little grease....this might help ya....http://67-72chevytrucks.com/vboard/s...d.php?t=157539
Also, if you haven't purchase one, I'd recommend a factory assembly manual as well....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
06-05-2011, 09:39 PM | #3 |
After all these years of abuse I agree most of the orignal regulators are shot. Little tricky for some to replace others don't have any problems what so ever. Find you a decent replacement regulator and go for it.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
06-06-2011, 05:38 PM | #4 |
06-06-2011, 05:41 PM | #5 |
i put one in from brother's and it worked great and that was with the one piece window conversion
06-06-2011, 05:57 PM | #6 |
I almost always use a board vendor for new parts then if something isn't right they are more likely to make it right plus they support this board.
06-06-2011, 06:01 PM | #7 |
06-06-2011, 06:46 PM | #8 |
06-06-2011, 06:50 PM | #9 |
it's alot cheaper to take off inner door panel and spray with lubricant and work the thhing slowly up and down while spraying // lots of times that is all that is required to get a moving part working is clean and lubricate
06-06-2011, 08:08 PM | #10 |
lube , won't fix worn out
06-06-2011, 08:44 PM | #11 |
Project Junkie! Fishing Poor!!
If it is just a little sticky it could be your weatherstrip, and not the regulator. The lower sill will catch on warn out weatherstrip and make it sticky feeling. So look at that also. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
07-15-2011, 05:27 PM | #12 |
Ordered a regulator,tool,pivot and screws and extra clips today.Its hot and I gotta get that window working.Will tackle it when parts arrive.Thanks for the info.
