Old 06-05-2011, 06:18 PM   #1
AusTx68
AusTx68's Avatar
Master cylinder bore size with stock booster?
I believe I have a 1" bore size master cylinder installed. Can I install a 1 1/8 master cylinder to push a 4 wheel disk setup? Will either size work with a stock size power brake booster?
I upgraded to 4 wheel disk but still have the disk/drum setup. The CCP unit is all in one which eliminates the need for a separate prop valve. They offer it in 1" and 1 1/8". I wasn't sure what determines the size needed. If they both bolt up to the brake booster I figured I should go with 1 1/8". It pushes more right?
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 06-05-2011, 09:07 PM   #2
colin_havens
colin_havens's Avatar
Re: Master cylinder bore size with stock booster?
I would like to know this as well...
colin_havens is offline   Reply With Quote
Old 06-05-2011, 09:14 PM   #3
Shane
Shane's Avatar
1 1/8" is the standard bore for Corvette master cylinders which a lot of folks use for 4 wheel disc brake setups.
Shane is offline   Reply With Quote
Old 06-05-2011, 10:09 PM   #4
AusTx68
AusTx68's Avatar
So both bore sizes will bolt up to the stock power booster?
It makes sense to think the 1 1/8" would push more volume.
Old 06-06-2011, 12:03 AM   #5
Shane
Shane's Avatar
Yes sir. I have a 1 1/8" corvette master cylinder bolted to truck brackets and truck booster on my '67.
