Old 06-05-2011, 08:30 PM   #1
dep378
inside door handle & hinge pin
My driver side door is off & won't close or open easy. The lower hinge pin is loose & needs replace. How do i get it out & where can I find replacement. Also, the i/s door handle is loose. How can I tighten it up. It flaps around & I have to push/pull to get it open. A lot of it has to do w/ the pin, but there is a lot of play in the handle. Thanks
dep378 is offline   Reply With Quote
