06-05-2011, 09:44 PM | #1 |
68 chevy wheel size
Ok im building a 68 up and need some help with wheel sizes. The pickup started out being a heavy 3/4 ton and i converted it to a 1/2 ton. While i did the 1/2 ton swap i put 4 inch drop coils in the the rear and lowered the front. How wide of wheel/ tire combo can you go without tubbing the bed?
06-05-2011, 11:51 PM | #2 |
Hand Crafted C-10
Re: 68 chevy wheel size
EOChev, I’m sending you to our suspension pros for an answer.
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
06-05-2011, 11:53 PM | #3 |
thanks, any help i can get is appreciated. Im just to the point where i need to get wheels and tires
06-06-2011, 12:14 AM | #4 |
Max wheel width varies depending on final ride height.
With a 4" drop & the stock size tubs you mentioned, a 10" wide wheel will prob be about the most you can easily squeeze.
06-06-2011, 08:47 PM | #5 |
thanks, and I forgot to ask also what back spacing people have used and look good
06-06-2011, 10:25 PM | #6 |
5"
