Old 06-05-2011, 09:54 PM   #1
paintslinga2010
Fuel pump to carb line.
I went at the fuel line fitting at the carb with a crescent wrenche in an attempt to change the filter. I turned the larger fitting and it turned easily. The problem was i was too stupid to realize that the fuel line was twisting as well. Now the truck wont start and i think it is due to the line being pinched. Are there an alternatives to buying a new $25 line from LMC? I also dont really want to bend line. Is there any way to use rubber hose?
paintslinga2010 is offline   Reply With Quote
Old 06-05-2011, 10:15 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Fuel pump to carb line.
I would just cut off the steel line after the alternator and run a fuel hose and also you'll need a fitting to go to the carburetor
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 06-05-2011, 10:30 PM   #3
irving216
definatly keep the hose away from moving parts and the headers XD twouldnt be too good.
irving216 is offline   Reply With Quote
Old 06-06-2011, 08:11 AM   #4
paintslinga2010
Will it work if I just cut it off and slide a rubber hose over the cut off part? Or do I need to flare the end?
Old 06-06-2011, 08:48 AM   #5
donut
donut's Avatar
IMO, its not necessary to flare if all your doing is putting the rubber hose on it. Mine has been running for years this way, no leaks. Just be sure it's fuel line and sized properly.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 06-06-2011, 10:00 AM   #6
BamaDave
That is what I did.
BamaDave is offline   Reply With Quote
Old 06-06-2011, 08:57 PM   #7
paintslinga2010
Where did you guys get the fitting? I went to O'reilly's today without much luck.
Old 06-06-2011, 11:57 PM   #8
flamingbig10
6.0 powered square
I got mine at O'reilly's
Aaron
