06-05-2011, 11:36 PM | #1 |
welded steering wheel
So i bought a 67-68 steering wheel from a member and I go to put it on and before I can do that I find out that the PO had welded the steering wheel to the threaded shaft that goes through the column. My question is could I just pull that shaft out and place another in its place or would the whole column have to be replaced? Oh and the column is not a tilt, I felt that one coming.
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
06-05-2011, 11:45 PM | #2 |
Re: welded steering wheel
Oh, you have to post a pic of this!
In fact that would be a great thread... PO's Hall of Shame Think you gonna need to pull the whole enchalada
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
06-05-2011, 11:50 PM | #3 |
Its dark outside let me go out and see if I can take a good picture of it.
06-05-2011, 11:53 PM | #4 |
I'm ssigned on
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
06-06-2011, 12:05 AM | #5 |
look
06-06-2011, 12:07 AM | #6 |
i think he lost the nut and maybe that loose screw in his head.
06-06-2011, 12:08 AM | #7 |
I don't see any reason why you can't replace the shaft, but it may be a challenge unwelding the wheel and shaft...
06-06-2011, 12:12 AM | #8 |
I dont think I wanna fool with unwelding the wheel off because then I would have to re-thread the shaft. I much rather replace it.
So if anyone out there would like to donate a tilt column to fix my problem I wont be mad...trust me.
06-06-2011, 12:42 AM | #9 |
The Older Generation
Looks to me like someone mushroomed the end of the shaft from beating on it and couldn't get the nut on so they just welded it. If you take a small grinder or cutoff wheel I don't think it would take much to cut through the weld. Before you try to pull the shaft out I would remove the neutral safety switch. If the shift tube moves much it may break it. If you have or can find a complete column that may be the way to go... LockDoc
06-06-2011, 02:53 AM | #10 |
i think i gotta shaft.... you can have it if you wanna pay for shipping
70 c10 long bed 57 chevy 2 door wagon 07 tahoe 96 civic commuter |
06-06-2011, 03:21 AM | #11 |
Fabricate till you "puke"
Well, thats a little "spooky", but not as bad as one of the buds back in the day? Dude pulls up in a 53 f-100, says "hey lets go for a ride"......manual steering in that old straight axle truck, & what was WELDED to the shaft? If you havent guessed it, it was a rusty old pair of vise bites! well Dave, you have a cool truck.....but I dont have time to ride in it I would replace the shaft also, just pull the coluom as a unit & take it apart (no biggie)....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-06-2011, 04:15 AM | #12 | |
Awesome people on this forum...
06-06-2011, 02:28 PM | #13 | |
very much appreciated....just let me know what shipping would cost me to 75040. Thanks.
06-06-2011, 03:16 PM | #14 |
i think the pictures need to be loaded to failblog:
http://thereifixedit.failblog.org/ Would be a good addition, |
06-06-2011, 06:55 PM | #15 |
06-06-2011, 07:32 PM | #16 |
~Rest In Peace~
nice work billy bob
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
06-07-2011, 12:35 AM | #17 |
well i found the shaft in my backyard but it looks like my son was beating on it cause the end with the threads is all mushroomed
06-10-2011, 02:51 PM | #18 |
bummer sometimes anything makes a good punch
06-10-2011, 06:47 PM | #19 |
So you need the entire length of the shaft for the column (making sure I understand correctly)? Then you plan to install that into your column?
Anyone know if there's a difference between the shaft from an auto column vs. a standard/3spd shift column? Reason I ask is I should have one out of a standard shift column in my garage.
