06-06-2011, 07:23 AM | #1 |
73-74 grill & bezels to 79.
I want to fit the pre 79 style headlight bezels to my 79 C20. I have purchased a LMC speciality grill part #38-4035, but I'm unsure of what other parts I need. Is it just the bezels or do I require other mounting brackets ? Do I also need a new lower grill trim piece ?
I cant just go to my local junkyard as these vehicles arent very common in Australia. I do prefer the mid 70s headlight bezels than the 79 style... |
06-06-2011, 10:12 AM | #2 |
Re: 73-74 grill & bezels to 79.
it's a direct swap all you need is the lower trim and the bezels and everything bolts/screws in place of the originals as for the grill you will probably have to fab up some brackets if you can't find any in the junkyard
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 Last edited by bmchevy1979; 06-06-2011 at 10:13 AM. |
06-06-2011, 12:33 PM | #3 |
yeller
You will also need the outer grill brackets, and center support and hood release assembly, all off a 73/74 truck.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
06-06-2011, 01:10 PM | #4 |
Getting Old; Going Broke
I don't think he will Jeff, not with that aftermarket grille he is getting from LMC. It has a footnote that if you have a 73/74 and put this grille in, you have to buy the adapters for it. Otherwise I think it's a direct swap, only needing the lower grille molding and different headlamp bezels.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
06-06-2011, 01:18 PM | #5 | |
Charlie Daniels w/ a Tq Wrench
Edit: oops, Randy beat me to it
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s Last edited by GCncsuHD; 06-06-2011 at 01:19 PM. |
06-07-2011, 08:43 AM | #6 |
Just the info I wanted to hear, thanks. I'll order the new bezels and lower trim. No issue fabbing brackets if needed.
06-08-2011, 06:32 AM | #7 |
Ok so i've just noticed LMC have 2 different part numbers for the upper grill moulding. Part number #38-3962 - 73 to 78 and part number #3839-63 - 79 moulding. Would I be right in saying I need 38-3962 or are both upper trims identical ? And its just the lower trim thats different ? Different length for uppers perhaps ? If anyone could confirm this that would be great as I have already purchased a new upper 79 moulding before I decided to swap to the earlier bezels. They look 1000 times better than the 79.
