06-06-2011, 08:44 AM | #1 |
Tire question (need Pics)
So I bought Nitto NT05 tires for the back of my truck and I went from a 35 to a 45 on the side wall and well its alot bigger than what I expected but im not really sure if I dont like it. maybe im growing out of the rubberband tires. anyway I need a tire for the front and the kumos that are on it are a 40 which still seem pretty thin so I was wondering id some one had pics of a 18inch wheel with a 40,45,50 side wall tire so I can maybe see what looks the best
Corey Jones Designs CoreyJonesDesigns on instagram Ole Silver- 1967 stepside http://www.hotrod.com/articles/1103c...chevrolet-c10/ http://67-72chevytrucks.com/vboard/s...d.php?t=598758 |
06-06-2011, 08:51 AM | #2 |
Charlie Daniels w/ a Tq Wrench
Re: Tire question (need Pics)
Knowing the section width would help, you can't calculate the sidewall height without it since it is a function of the section width and the aspect ratio you gave.
Just guessing a 285 section width in the rear, you went from a 3.9" sidewall to a 5" sidewall with the 45 series. That's an increase of 1.125" of sidewall, or about 2.25" overall height of the tire. Again, just guessing a 255 in the front, a 50 series tire would give nearly the same exact 5" of sidewall as the rear.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
06-06-2011, 08:56 AM | #3 |
well my rear is a 255 45 20 and the front as of now is a 235 40 18
worst mistake i made on the truck was I didnt go wider with the wheels
06-06-2011, 08:56 AM | #4 |
but yea I would like the front to match the back or be very close
06-06-2011, 09:04 AM | #5 | |
The rear 255/45R20 has a 4.5" sidewall, overall tire height of 29". The front 235/40R18 has a 3.7" sidewall, and overall height of 25.4" Going to a 235/45 in the front would give a sidewall of 4.16" and overall height of 26.3". 235/50 would give 4.6" sidewall and 27.25" overall height. If you wanted to bump the width up to a 255 in the front a 255/45R18 would have the same 4.5" sidewall as the rear with 2" shorter overall height at 27". All these numbers are going directly off converting the tire size listed, obviously each manufacturer would have varying exact specs (otherwise there would be oddball sizes like 251/47R20 haha). Most manufacturers list their actual specs on their website or tirerack usually has them listed as well, but they shouldn't vary more than 1/4" or so from what I listed.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s Last edited by GCncsuHD; 06-06-2011 at 09:08 AM. |
06-06-2011, 09:05 AM | #6 |
225x60 on the front is 28.64". Your backs are 29.04". That would be close.
06-06-2011, 09:11 AM | #7 |
That would be close in overall height, but would have a 5.3" sidewall, about 3/4" bigger than his rear. I was under the impression he was more or less trying to match the height of the sidewall more than the overall height of the tire since he has staggered wheels.
06-06-2011, 09:12 AM | #8 |
thanks guys
06-06-2011, 09:13 AM | #9 |
your right GCncsuHD
06-06-2011, 09:28 AM | #10 |
Glad I can help, sorry I don't have pics, I've never ran a tire that small
06-06-2011, 11:09 AM | #11 |
Here is a 245/ 50 18 for comparison on my fronts. The back tires are 255/55 18's.
