Old 06-06-2011, 09:50 AM   #1
mlevario99
Exclamation Side window glass how to
I need to remove the big side window glass from a suburban that I just bought and install them in another suburban that I have. What is the best way to remove them along with the seal, anyone has done it.
mlevario99 is offline   Reply With Quote
Old 06-06-2011, 10:52 AM   #2
vectorit
What?
vectorit's Avatar
Re: Side window glass how to
The rubber seal is usually petrified, so the best way I have found is to use a box cutter knife and carve the rubber seal away from the glass.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 06-06-2011, 11:23 AM   #3
mlevario99
vectorit, thanks, the seals appera to be in good conditions, is there a way to remove the glass with the seal, without damaging the seal
thanks
Old 06-07-2011, 02:37 AM   #4
ole red
The best way I have found is by using some WD 40 and about 4-5 putty knives and 4-5 flat screw drivers. And work a little at a time and begin in the etiher top corner.
69 stepside, 1/2ton, 4X4, 350/350/205
ole red is offline   Reply With Quote
Old 06-07-2011, 09:19 AM   #5
mlevario99
thanks ole red, I will give it a try and see how it goes.
