06-06-2011, 10:44 AM | #1 |
yes, i do
audible "click/knock" heard from passenger side inside cab
i have an audible click/knock that i can hear inside the cab of my 01 tahoe, but barely if i can hear if i open the hood and rev the engine. i can't hear it in the engine or transmission if i use a stethoscope, but if i take the stethoscope and put it on the exhaust pipe/manifold i can hear it, even more so if i put it on the heat shield. there is the same kind of sound under the valve cover, but doesn't sound like a rocker arm. i know what those sound like from gen 1 sbc's. but i did hear clicking from the injectors when i put the stethoscope on them, but the driver's side injectors did the same thing, just no sound from the driver's exhaust like what i get from the passenger's side exhaust. the only mods that i have on my tahoe are p&p on the tb, k&n drop in filter, and electric fans. and this sound didn't start until after i pressure washed the engine a couple weeks before i did the p&p tb and e-fan conversion. is it possible the injectors are going? or possible sticky valves? i saw no carbon tracks indicating leaks, and the sound under the hood gets harder to hear with the rpms, but the clicking gets faster and slightly more noticeable in the cab. oil pressure is great
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
06-06-2011, 09:32 PM | #2 | |
#16876
Re: audible "click/knock" heard from passenger side inside cab
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
06-06-2011, 09:37 PM | #3 |
Mine was more of a clunk. Good memory, I don't notice it anymore.
The dealer tried to fix it with a section of flex pipe in the exhaust. Sounds like yours may be different?
"I feel the need for speed!"... as soon as I am done with my nap. |
06-07-2011, 02:54 AM | #4 |
yes, i do
well i was listening to it more today and its kind of a hollow knocking sound, but if i try to listen under the hood then its not very noticeable. if i take a stethoscope to my passenger exhaust i can hear it, but not really from the engine. i'm wondering if its a sticky valve, because i can kinda hear it under the valve cover, but it gets amplified if i listen to the heat shield.
06-07-2011, 04:54 PM | #5 |
Has more rust than truck...
Is the click/knock consistent with engine speed? Do you get the same sound form the drivers side valve cover? No matter what, if you think its a valve pull the valve cover. The gasket is reusable so it wont cost you anything.
