Old 06-06-2011, 08:40 PM   #1
cjohnson6772
cjohnson6772's Avatar
Tilt columns
How hard is it to rebuild an original truck column?
What are the pieces that you would say should ALWAYS be replaced?
What should I look for in a good used column (typical problem areas)?
cjohnson6772 is offline   Reply With Quote
Old 06-06-2011, 10:23 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Tilt columns
I can't answer your Q's but there is a great write-up with exploded views here.
ETsC10 is offline   Reply With Quote
Old 06-07-2011, 01:41 PM   #3
Eddie H.
Eddie H.'s Avatar
Re: Tilt columns
It's not that difficult. Just disassemble, clean and inspect all the parts and replace anything that shows excessive wear. (Usually, upper and lower bearings and turn signal switch)
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
