Old 06-06-2011, 11:26 PM   #1
Husker
Husker's Avatar
Lift on 70
I installed a 4" lift, front springs rear shackle kit from ORD. How many of you out there are running Pinion shims?
IMy truck has a problem when hits a bump acts like the front tire has a wobble or such. The shims were on the springs when I got them(used) and the truck is doing it both with the shims and without. My ball joints are only a couple of years old, and it did not act this way before lift was added.
thanks
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 06-07-2011, 06:08 AM   #2
Blazer1970
Blazer1970's Avatar
Re: Lift on 70
What did you do for steering correction?
Blazer1970 is offline   Reply With Quote
Old 06-07-2011, 07:17 AM   #3
Husker
Husker's Avatar
Re: Lift on 70
Raised steering arm that mounts on the knuckle.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 06-11-2011, 06:41 PM   #4
liftlawssuck
liftlawssuck's Avatar
Re: Lift on 70
Called bump steer. Straighten out the alignment of drag link. This should fix the problem. If not. What size tires you running. Steering stabilizers should be installed as well. Hope this helps.
liftlawssuck is offline   Reply With Quote
Old 06-11-2011, 09:32 PM   #5
Husker
Husker's Avatar
Re: Lift on 70
33" BFG AT's on 10" slots with steering stabilizer.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 06-11-2011, 11:21 PM   #6
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Re: Lift on 70
Is your suspension nice and tight? Lift the wheels and see if they have any play from side to side or up and down. May be the ball joints or bearings. I'd hesitate to say your truck would suffer from bump steer if you are "only" running 33s and 4" of lift.
The steering stabilizer will keep the truck from wandering all over the road, but again, I haven't seen a "need" for one with 33s and 4 inches of lift. The raised steering arm should be enough to get the truck to do what it is supposed to.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 06-12-2011, 12:03 AM   #7
muddstir
muddstir's Avatar
Re: Lift on 70
check all other steering components and bearing in the front end. i just put a 4in lift in in my 70 and it was impossible to keep strait, but the tie rod ends were shot and wheel bearing were loose
1970 4x4 1/2 lwb -new ride-
1971 2x4 1/2 lwb -yard ornament
1980 4x4 3/4 lwb -currently dismantled
1997 chevy cavalier =daily driver
1998 chevy cavalier -full coverage plan
2007 kawasaki vulcan 900 - garage ornament
muddstir is offline   Reply With Quote
Old 06-12-2011, 05:33 AM   #8
1malo68
1malo68's Avatar
Re: Lift on 70
You gonna be driving it through the flood water?
1malo68 is offline   Reply With Quote
Old 06-12-2011, 09:13 AM   #9
LONGHAIR
Re: Lift on 70
It's not bump steer, which cannot occur with a straight-axle vehicle. Bump-steer is a change in the "toe" measurement that happens during suspension travel.
What you are experiencing it likely what is referred to as "death wobble". It comes from a combination of several factors. Virtually any looseness of parts that are associated with the front wheels contributes to this, or makes it worse. (wheels bearings, tie-rod ends, ball-joints, drag link ends, etc. as far as "hard parts") Then there are a few "adjustments" like caster and toe-in that can get it started.
The short (front to back) drag-link doesn't help matters either.....This is at least part of the reason that "cross-over" conversion is so popular.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-12-2011, 10:15 AM   #10
liftlawssuck
Re: Lift on 70
Sorry, roll steer. As wiki says, for simple analysis it's OK to assume roll steer and bump are the same thing.
Bottom line is. You gotta make sure that drag link is straight. Most commonly done by a raised steering arm.
Old 06-12-2011, 09:06 PM   #11
Husker
Husker's Avatar
Re: Lift on 70
Thanks guys, will try suggestions. Also throwing some new shocks at it.
So far the flood not too bad here.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 06-12-2011, 09:32 PM   #12
67chevy2wd
67chevy2wd's Avatar
Re: Lift on 70
I have a 71 with a 4" lift and 33's with out any steering corrections. The drag link is at a pretty steep angle. I bought it this way. It is all over the road when I get on and off the gas and every bump I hit with the left tire. I ordered a raised steering arm hoping it fixes my steering. Someday I want to do crossover when I can afford it.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
