Old 06-07-2011, 01:15 AM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
4x4 Converison cost?
Whats the approximate cost of converting a 1 ton 81-91 to 4x4? DRW, not SRW. Thanks, Bradley
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 06-07-2011, 07:33 AM   #2
b454rat
Re: 4x4 Converison cost?
All depends how cheap you can find the parts for and if you can do the work yourself. Probly the most expensive is the front axle.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 06-07-2011, 10:00 AM   #3
$1,000-3,000+/-.
If you can buy a junker and do the work,as cheap as $1,000 or even less.
If you buy and axles and all the associated parts it will get closer to $3,000. A lot depends n if the used parts are good to go or need attention,like brakes,king pins,seals,u-joints,etc.
Even more if you have to pay for fabrication or any other labor. The best way is find a donor for $1,000 or less. They are out there. A friend bought at least 3 last year off Craigslist and they were all SRW.
Old 06-07-2011, 02:51 PM   #4
thirdstreettito
Resident of Here
That's what I figured, thanks guys!
~Bradley~
Miss having a truck
