Blazer High Hump in truck?
Will a high hump cover from a 72 blazer work in a 68 pick up? Or are the truck floorpans different?
![]() Join Date: Aug 2008
Re: Blazer High Hump in truck?
They are all the same 67-72. You will need both the upper and lower piece. If the 68 was originally an auto or a three on the column you will have to cut out the section of the floor pan to be replaced by the high hump.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
What is this about an upper AND lower piece???
I did some searching on here about converting to high hump, and this is the first I've heard of this. Got any pics of what you're talking about? wanna make sure I get the right stuff. I'm mostly concerned if I can get the tunnel parts I need from a blazer or do they need to come from a truck? |
Just saw where someone posted that the 4x4 high hump is longer than a 2wd high hump...true statement??
The high humps are all the same size for 67-72. No difference between 2wd and 4wd.
You can get away with cutting out your low hump and drilling all the bolt holes and then either weld nuts under them, or use two people to secure it. What I believe the person who mentioned getting both parts meant, was cutting out the bolt hole area surrounding the opening and welding that back in for a more factory look.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
