steel wheel help
I'm needing a pair of 15x6 or 15x7 5 lug steel wheels with less then 4" of backspacing. Is there any stock wheels out there like this? Anything aftermarket? I'm needing the factory style wheels with the bumps for the dog dish hubcap attachment.
All the wheels I've come across have 4" backspacing. 3 1/2" or 3 5/8" backspacing would be ideal. Thanks,
Doug Looking for a 67-72 short bed driver..... Last edited by m6z; 06-07-2011 at 11:21 PM. |
Re: steel wheel help
#3 | |
Doug Looking for a 67-72 short bed driver..... |
![]() Join Date: Oct 2009
I might be wrong, but I would think stock 15 x 6 wheels off of a '71 or '72 1/2 ton would be exactly what you're looking for.
![]() Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
Old Skool Club
![]() Join Date: Jun 2001
Any GM full-size car (Buick, Olds, Cadillac and Pontiac) up to '77, should have a wheel you could use. Chevrolet full-size in '71 and up, also used 15's. Any of the GM trucks (1/2-ton) from '71-87 should also have wheels that you can use.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#7 | |
Doug Looking for a 67-72 short bed driver..... Last edited by m6z; 06-08-2011 at 07:49 AM. |
#8 | |
Anyone? Where can I find a 15X6 or 15X7 with less then 4" of backspacing?
Old Skool Club
I have a pair of aluminum split-six wheels that are 7 inches wide and have a 3.5 inch backspace. I had to run them on the front of my '96, because the backside of the lower control arms would come into contact with the rims of anything with more backspace, like the 15x8's that were on it when it was lowered. I feel your pain, but I can't answer your question.
Look at www.wheelvintiques.com and see what you can find. I went with this wheel in a 16x7 to avoid the issue I mentioned above, on my '96. They are silver powder coat when you get 'em, but I didn't leave 'em that way.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 06-12-2011 at 10:26 PM. |
laying low
![]() Join Date: Mar 2001
Doug it sounds like your stock steel wheels are the 88 up models which do have more backspace. You would need truck wheels for the 87 and down and measure one of them. I think the 6" rims are in the 3 to 3 1/2" bspace range. Some guys also use aftermarket spacers behind their wheels to get an additional 1/4" or so clearance.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#12 | |
Thanks,
