Old 06-07-2011, 02:47 PM   #1
Prathbun
Prathbun's Avatar
Low Hump Cab Question
I want to swap from a 4 speed (high hump) to a TH 350 in my 72 cab. Is there a low hump bolt in panel that I can use?? What are my options??
Thanks!!
It's Not Rust, It's Patina!!
1967 C 20 Large Window, 700R4, 283, Tilt, PS, PB.....A Rusty But Trusty Gas Hog
2008 Silverado LTZ 1500 4x4
Prathbun is offline   Reply With Quote
Old 06-07-2011, 03:15 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Low Hump Cab Question
No BOLT-IN low hump.
You can weld up the shifter hole in your high hump.
The big block trucks with the th-400 trans had the high hump.
Easy solution and then just buy new carpet or rubber floor mats to cover the fact that it was ever a 4-speed truck.
Keith
Convert to disc brakes.
Old 06-08-2011, 04:25 PM   #3
Prathbun
Prathbun's Avatar
Great, thanks for the info Keith!!!
Old 06-09-2011, 12:25 AM   #4
profe56
I'm working on these: I cutted a low hump panel and putted under big hump
Uploaded with ImageShack.us
and I cutted with a jigsaw and did the holes
profe56 is offline   Reply With Quote
