69 grille on 72
What all would i need to install a 69 grille on my 72?
Re: 69 grille on 72
You need the outer grille, inner grille, hood latch and the middle support bracket. The lights should all be the same hookups from what I recall. I went from 69 to 72 when I did mine. Not a real hard swap. If I missed anything someone will pipe in I'm sure.
1969 chevy C10 long bed 350 4bbl auto p/disc and 5 lug |
Re: 69 grille on 72
Just did mine, no problems. Make sure and sandpaper the outer grille to fender mounting down to clean metal to help with turn signal grounding. The whole middle brace with hood latch just bolts in. A much better looking grille in my opinion. Are you doing the bumper swap as well?
VA72C10
![]() Join Date: Mar 2008
Re: 69 grille on 72
you'll also need the 69-70 light buckets and lenses that bolt in the grille and a different bumper (67-70 unless you want to use the holes in the bumper as a spot for foglights or have 4 turn signals
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 06-07-2011 at 06:29 PM. |
