Old 06-07-2011, 09:03 PM   #1
383Chevy
[><]Sofa King Dirty 4x4[><]
383Chevy's Avatar
I keep blowin the dash light fuse
Any idea whats causin this? i put a new fuse in and turn the dashlights on and drive around and a few minutes later it shorts out
00' Chevy Silverado 1500 z71
33"s
3" lift
5-speed
Past trucks
85' Chevy C10 Step side
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
92' S10/Tahoe sbc swap
383Chevy is offline   Reply With Quote
Old 06-07-2011, 10:12 PM   #2
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Re: I keep blowin the dash light fuse
Maybe some of the lights are grounding out, but I think that would be a little faster than a few minutes. More like a few seconds. I had a similar problem with my old 78 Chevy... I just put a bigger amp fuse in it and the problem went away.
Your headlight switch could always be going bad, too... at least something to check out.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 06-07-2011, 11:32 PM   #3
f.monroe
f.monroe's Avatar
Dash light fuse is linked to the rear running lights .Chech the wiring running along the frame all the way to the rear. They may be pinched between the frame and the bed somewhere. When you have no dash lights it is a sign that the running lights are also out. The brake lights and turn signals will work but the running lights will be out.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 06-08-2011, 01:05 PM   #4
75ChevyGuy
GM Parts Guy
75ChevyGuy's Avatar
I had the same problem on my truck. It was actually the bed crushing the four wires for the rear lights. Rerouted the wires and the problem went away. Or you could try putting in a circuit breaker for a short term solution. They make some that fit right into where the glass fuses would go.
1975 Chevrolet C-10 Custom Deluxe (DD/WIP)
1989 Chevrolet C1500 reg cab stepside (Winter Truck)
1977 Harley Davidson XLH 1000 (Summer Cruiser)
75ChevyGuy is offline   Reply With Quote
Old 06-08-2011, 02:20 PM   #5
383Chevy
383Chevy's Avatar
Not only this but when i put my turn signal on left my gas gauge goes way down past E
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 06-08-2011, 02:27 PM   #6
spudz
spudz's Avatar
Sounds like you are missing a ground somewhere. try your ground bus to the left of the column.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 06-08-2011, 02:56 PM   #7
383Chevy
383Chevy's Avatar
Any idea what these wires are for? they looked like there supposed to hook to the light switch and they lead to the dash but i dont know where to hook em up ?
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
