Always a work in progress
Choosing the right tire
For all you racers, how do you choose the right size tire(slicks)? Compound?
I don't want to just guess and I know there has to be some formula to getting the right size and compound. Here is some info on my truck so that maybe you can help me out here: 85 swb hopefully around 3600lbs after a diet 390" Stroker LS Iron block in the neighborhood of 450rwhp AFR 230cc heads(box stock) Port matched Vic Jr with 1200cfm 4150 style throttle body. Custom grind cam th400 backed by a 9" w/3.50 gears(will eventually have a turbo), Yukon locker and 35 spline moser axles. Stock front suspension with appropriate springs and adj shocks, stock rear supension flipped w/caltracs and adj shocks Help a brotha out!!
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
Re: Choosing the right tire
With what you have listed here, a 28x10.5 should handle the job. The idea is to have enough tire to hook, without having the extra weight, and height of a tire that is too large. The 28 inch tire will also help with your gear ratio some. Hope this helps. Paul Baxter
At the body shop.
I love my hooiser drag radials. 325/50 15 1.671 60' foot braked
Hooks great and dead stable at 110 mph Opinions differ though. Posted via Mobile Device
" That didnt make it any newer " " Dont antique the equipment " |
kpeztruck-yes it does help, thank you.
kqql it-i looked at those but i think i am going to with a full on slick
If you can get them to work the radials are faster.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
I guess it can't hurt to try them then. I thought it was the opposite, but that is why I ask these questions here and not on some of the other boards. Thanks DJ, when is your beast gonna be back on the track?
I'm trying to get it to the chassis shop then the paint shop so cross your fingers.
djracer is correct, the radials are faster. But, trickier to hook. I have run both, and can tell you that the slicks are more forgiving on marginal tracks, and when the slightly over-agressive tuner(me) gets greedy.LOL I will try both again when mine is at the track again, but the classes I want to run are 275 radial/28x10.5 tire classes. Paul Baxter
Registered Truck Offender
You guys running radials,,,, dude, my hats off to ya. The radial classes are frickin AMAZING. I have a hard enough time getting a great big ol pfhat 14x33 D5 slick to hook consistantly!
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
I might try the radials 1st just bc of the price tag and not having to run a tube. I didn't realize how expensive tubes are.
On a budget like Fred Sanford
You don't have to run tubes in the bias ply's, lots of guys (myself included) don't run tubes. Radials are sweet if you can get them to work, but if you don't, they'll tear sh!t up quick. I tore up a 9" ring/pinion because the radials shook so hard on a poorly prepped track.....they're my "street" tires now.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
I am new to slicks so bear with me, even if a tube is recommended you don't have to run one?
#13 | |
#14 |
Does the tube keep the bead seated against the rim? Is there another purpose for the tube? I really would hate to put screws in a brand new wheel.
#15 |
The tube supposedly makes the tire more consistent and stable on the big end. To me, it's just more rotating weight.
![]() At the power level you'll be at, you shouldn't have problems spinning the tire on the rim so you shouldn't need screws. I make around 700rwhp in my camaro and don't need screws yet. If you run tubes, you absolutely have to run screws to keep from shearing the valve stem off if the tire were to slip on the rim.
#16 |
Ok I think I am getting it now
#17 |
At the body shop.
![]() 325/50 on a 10" wheel Hoosier Dot radial Posted via Mobile Device
