06-07-2011, 11:50 PM | #1 |
Switching to 5x4.5 Lug pattern on a 64 c10
Anyone make rotors for the 73-87 1.25" rotor spindle? Or adapters? I have a dropmember so I am sucked in a little anyways so adapters wont be so crazy.
What rear end should I put in? Jeep? Ford? 9" are out of my budget So i was thinking ranger or mustang. My buddy has a cherokee rear laying around that has the pattern i need, but im not sure about the strength. Im going with a 3 link so welding was going to be required anyways. I won a set of Shelby cs56 20x9 +35 and 20x10 +45 that I think are bad ass. |
06-09-2011, 12:31 PM | #2 |
67-72 parts collector,…
Re: Switching to 5x4.5 Lug pattern on a 64 c10
Your 9" wide front wheels are going to have a 6.37" backspace.
The 10" wide rear wheels are going to have a 7.27" backspace. I think I would use the stock rearend and run spacers/adapters front and rear to convert from the stock 5x5" pattern to the 5x4.5" pattern. Otherwise you are going to have to find a rearend that is approximately 2"-3" wider than your original rearend housing.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 06-09-2011 at 12:31 PM. |
06-09-2011, 02:48 PM | #3 |
I diont have a rear end at all right now. I sold the 6 lug rear end, to get money for 5x5 rear |
