Old 06-08-2011, 12:05 AM   #1
72oldblue
Replacement Power Steering Hose?
Hello - I need help finding a power steering hose that will work for my old blue 72 chevy which has a 402 big block in her. I know the original GM part has been discontinued (GM part #3975151). It is the pressure hose that runs along the top of the frame the bends upwards and into the power steering pump/can.
What other hose part numbers have been used in place of the original?
I will try to get some pictures posted.
Thanks in advance for the help.
72oldblue is offline   Reply With Quote
Old 06-08-2011, 12:21 AM   #2
72oldblue
Re: Replacement Power Steering Hose?
Photo posted, it is the hose marked with the red line.
Any help would be greatly appreciated!
Old 06-08-2011, 09:06 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
_
I have a NAPA number for one of the remote reservoir hoses but I don't remember which hose it was. The number is NPS 73306. I would think the number for the other hose would be close to that if this one is not the right one.
LockDoc
Leon
Old 06-08-2011, 09:31 AM   #4
DT1
DT1's Avatar
You can get the hoses from LMC or other classic Chevy truck sites. Be careful though. I got mine from LMC and as I have experienced many times with them before, this part, as well as others doesn't fit properly. I had to cut the hard line and install a Swagelok coupling to get it to clock right.
DT1 is offline   Reply With Quote
Old 06-08-2011, 11:25 AM   #5
72oldblue
Thanks for the replys, but I would prefer to not to have to cut/splice the line to make it work.
I am sure someone out there has information for a good replacement part for this discontinued big block item.
Bump, Bump, Bump.
Old 06-08-2011, 11:59 AM   #6
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
remove the hose, walk into a industrial equip./hydraulic parts house, and see if they can make you one. i know that my local napa makes these hoses and brake hoses.
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 06-08-2011, 12:05 PM   #7
custom1970
Member
custom1970's Avatar
Please let us know if you find one. I ordered one from LMC or Classic, but it was the wrong one. Went to every auto parts store around here and for some reason they all show the same hose in there books, but it's wrong!! NAPA actually told me that my someone changed the engine in my truck, that chevy didn't put BB in them, i just walked out... not worth arguing with them.
I finally had to take it to a hydraulic shop, had them cut off the ends, weld them to hydraulic fittings and crimp on new hydraulic hose, cost like $40.00. Might have a pic of it, will look and see.
1970 CST LB Fleetside, 402 BB, PS, PB,AC
1968 Firebird 400 conv.
1965 Chris Craft 17' wood ski boat (SN #0001)
custom1970 is offline   Reply With Quote
Old 06-08-2011, 12:12 PM   #8
custom1970
Member
custom1970's Avatar
Found a pic of new hose installed, not a great pic, but it doesn't look that bad in the truck
Old 06-08-2011, 04:37 PM   #9
68gmsee
Active Member
68gmsee's Avatar
These trucks have been changed around and parts replaced for the last 40 years to the point where parts don't necessarily match between them so it will be hard to get the exact same hose.
I know I've replaced the gearbox on my 69 twice and both times I went to junkyards and got the complete asm including hoses from the donor vehicle. One of them was a Dodge truck.
Best bet, as mentioned above, is to take it to a good hydraulic line shop. These guys are experts at doing that kind of work since they deal with a lot of industrial type stuff.
68gmsee is offline   Reply With Quote
Old 06-08-2011, 08:46 PM   #10
72oldblue
Thanks you everybody for your replys!
I think I got lucky, I did a search on the original GM part #3975151 and found one at the following site:
http://www.oldsmobileobsolete.com/it...r-/lid=3829321
Looks like I bought the only 1 they had. We'll see if it fits when its delivered. I will let you all know.
Old 06-09-2011, 12:00 AM   #11
profe56
Yes, NAPA has it, I bougth one about 3 weeks ago.
profe56 is offline   Reply With Quote
Old 06-09-2011, 01:57 AM   #12
kcsa75
kcsa75's Avatar
RockAuto.com
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 01-03-2012, 12:34 AM   #13
hdpete98
Originally Posted by kcsa75 View Post
RockAuto.com
Wrong part does not fit. Same for the NAPA part.
Anyone had any luck sourcing the correct one, gm#3975151?
hdpete98 is offline   Reply With Quote
Old 01-03-2012, 12:44 AM   #14
leddzepp
Moderator
leddzepp's Avatar
Thumbs up Re: Replacement Power Steering Hose?
You will never find one. You are in luck though....board vendor Pickmup has some for sale that he had made up and are EXACT reproductions. Here is the link: http://67-72chevytrucks.com/vboard/s...d.php?t=497627
Welcome to the board neighbor!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 01-03-2012, 12:55 AM   #15
no moa
no moa's Avatar
I bought the set pickmup makes, they are great quality.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 01-03-2012, 11:03 AM   #16
hdpete98
Thank you!!!!
Old 01-03-2012, 11:33 AM   #17
RenoKeene
Florida Edition
RenoKeene's Avatar
I got mine from pickmup too, real nice!
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 01-03-2012, 01:51 PM   #18
MARKDTN
The ones from good parts houses don't fit? Over the years, I have used many CarQuest hose assemblies made with good quality Gates hose and never had an issue. What is so unusual about this one?
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 01-03-2012, 08:23 PM   #19
hdpete98
It is not a quality issue. It is the wrong part in the catalog/computer. Take a look at your hose and compare to what catalog has and you will see. GM discontinued the part and no aftermarket supplier picked it up. Propably due to lack of demand since it is only for BB's.
Old 01-03-2012, 11:34 PM   #20
LockDoc
LockDoc's Avatar
After looking at the OP's picture again it looks like his pump and reservoir are integral. Didn't all big block trucks have the remote reservoir from the factory? Maybe that's why none of the hoses he gets will fit.
LockDoc
Leon
Old 01-03-2012, 11:41 PM   #21
leddzepp
Moderator
leddzepp's Avatar
LockDoc
The OP posted this thread 6 months ago...there was another person that brought it back up to the top. Also, the OP 's picture is cutting off the remote reservoir hose coming in at the top of the pump. If he had centered the pic a little farther forward i believe you would see it.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 02-04-2014, 02:01 PM   #22
9teen69
9teen69's Avatar
It's alive...
Anyone have pictures of the hoses from PICKMUP?
PICKMUP- I'd like to order if correct...needing pressure and return for 72 small block, thanks
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 02-04-2014, 02:13 PM   #23
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by 9teen69 View Post
It's alive...
You might want to try the parts board.
http://67-72chevytrucks.com/vboard/s...d.php?t=545846
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
