06-08-2011, 03:41 AM | #1 |
Normal???
Water pump leaked a bit after installation. Stopped after awhile. Is this normal for a new (actually reman) water pump?
06-08-2011, 07:56 AM | #2 |
Re: Normal???
Where is it leaking? Shaft? between pump and block? around hoses?
Randy Summers Never brake in the learning curve! 1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737 |
06-08-2011, 08:05 PM | #3 |
Re: Normal???
Couldn't really tell. It was running down the front of the motor. All I know is it stopped.
06-08-2011, 09:25 PM | #4 |
Re: Normal???
I wouldn`t call that normal. Are you sure it wasn`t just residual coolant?
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD 84 Chevy K30 CC SRW 55 Chevy 210 2dr post |
06-08-2011, 11:55 PM | #5 |
Re: Normal???
It sure coulda been.
06-09-2011, 12:15 AM | #6 |
Re: Normal???
I would keep a close eye on it. If it leaks any more you have issues. If it aint broke don't fix it.
06-14-2011, 07:04 AM | #7 |
Re: Normal???
Can't see it leaking anywhere but the fluid is going somewhere. Not in the oil pan (checked it 1st!!). Radiator drops about 6 inches to work and the same back. That's about 15 miles round trip, about a gallons worth. Any ideas?
06-14-2011, 07:39 AM | #8 |
Re: Normal???
If its leaking, pull it off, get new gaskets. Get a can of high tack valve sealant. Clean it up really good. And put it back together. I had no leaks when I installed mine and still don't several months later.
85 C10 LWB 305ci - 700r4 - 10 bolt - 3:08 gears Collecting parts for a 'mild prerunner" |
06-14-2011, 08:11 AM | #9 |
Re: Normal???
Sealer on bolts too?
06-14-2011, 08:12 AM | #10 |
Re: Normal???
Really confusing me cause it don't leak while sitting.
06-14-2011, 08:49 AM | #11 |
78K & 79C Jimmys
Re: Normal???
A few years ago in the fall i had changed the water pump late into the night on my 89
used water checked it for leaks with water went to bed woke up the next day ran the truck down the street to get anti freeze the block froze and cracked leaked all over mine cracked around the engine mount but the leak came out the bottom in the same area hope yours has another reason,like just a bad rebuild
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
06-14-2011, 09:39 AM | #12 |
Re: Normal???
I just put it on the block, and the water pump that was it. and then put the gasket in between, dont over do it of course. But high tack gasket sealant is tons better than rtv sealant, and a million times better than that orange rubber S***.
Did you buy a rebuild or a brand new one?
06-14-2011, 01:07 PM | #13 |
Re: Normal???
Oreilly's rebuild.
